RonnieB2018
- Joined
- Jul 3, 2018
- Messages
- 5
- Tractor
- zd326
ZD326P
Issues began when the mower wouldn't shut off. Used the manual fuel shut off to stop the mower. Went to mow a few days later and the instrument panel was working (guages) and the fuel pump was energized. '
When the key was turned the glow plug light came on, but the starter never energized.
Checked continuity through the different key switch positions, all worked except the one labeled "ST" which went to the starter. Replaced ignition switch.
Turned the key, but nothing changed.
Double checked all safety positions. All good.
Jumped the starter with a screwdriver and it fired up fine.
At this point I began running through all of the safeties, but never found an issue.
Did the same with the fuses under the seat and the inline fuse going to the starter, still no issue.
Once I found the wiring diagrams I began to track wire by wire.
Tracked to the controller and the wire fell out of the wiring plug that connects to the controller.
Went to local kubota dealer. Tried to purchase a new contact for the plug, but was told that they didn't sell components, only a full wiring harness. Their "best guess" was a full wiring harness for 170.00. I asked if this was not the right part (as there was no picture) could I return it? "Yes, but with a restocking fee of 15%." I was blown away at this, so I called Kubota's hotline to see if I could find out more information about the controller's logic (if the power that this wire supplied fed something non-essential I didn't want to keep troubleshooting this wire when the mower wouldn't start) and if I could verify this harness, or buy a similar plug. They offered no help with the controller, couldn't be 100% sure that it was the correct wiring harness, and "didn't have a clue where to get just a plug."
Went to HR Agriculture, where they were able to provide a handful of different leads with pre-crimped contacts. Found one that was nearly identical in size, so I shoved it into the harness, flipped the key and it's now running.
Does anyone have any insight on Kubota's Controller? Even the WSM has very little information. I can make educated guesses for most of it, but a document to add to my notes would be even better. Attached is a picture of the wire, so that was if anyone else runs into this thinking they have an issue with the safeties, stop relay, starter, or any number of components they can keep this in mind.
5 - PTO Switch
17 - Controller
5 - PTO Switch
17 - Controller
