zetor 3340 4x4 info
   / zetor 3340 4x4 info #1
wendelin
Bronze Member
Oakley KS
JD 185
I was at an auction that had a zetor 3340 4x4 with a cab heat and air.
What is this tractor worth 1995 model with about 1000 hours look to be in good condition . I did not hear it run.
What is the smallest tractor zetor makes that has a cab?
thanks fo rall the info
wendelin
   / zetor 3340 4x4 info #2
According to my 2004 Primedia Used Tractor Price Guide, the 1995 3340 4x4 with cab in good condition is worth around $10,000. This tractor is rated at 42.5 PTO HP. This is also listed as being the smallest Zetor with cab.
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2013 Minos-Agri 190B Disc Mower (A50860)
2013 Minos-Agri...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
