YM276D Brakes
   / YM276D Brakes #1
richriddle
Gold Member
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
The right rear brake on the old YM276D is frozen. I watched the video and ordered the new brakes from Hoye Tractor. The brakes should arrive on Monday. How difficult a job is it to remove the brakes when they are frozen? The video mentioned the cover plate is cast and to be cautious.
   / YM276D Brakes #2
The Hoye video is great. He takes the wheel off, I didn't, on the three Yanmars I've done. I think working there is safer with the wheel on. I suppose total job time is the same either way.
Usually the problem is the shaft stuck in the cover, not the shoes stuck, so it's a simple project. Note there's an o-ring at the exterior end of the shaft so you can't free up a stuck shaft by oiling it there.
The examples I've worked on had everything stuck worse than Aaron's example. I took a thin flexible putty knife and drove it in at several points around the perimeter of the cover to get it loose. There's a paper gasket, so there's a little slack to drive the putty knife into. Take it easy driving the shaft out of the cover, don't bend or break it! Penetrating oil, time, twisting the lever instead of a direct push, will eventually loosen it. Don't overlook the snap ring!
You can swap old front and rear shoes on each side to even out the wear. Also on some models the 'dead' anchor at the far end of the shoes can be rotated a quarter turn to bring half-worn shoes closer to the drum. I used non-runny silicon lube on the o-rings and shaft, so it wouldn't seep onto the shoes.
This is an easy project, NBD. The stuck brakes I freed up in 2004 still move freely, and the original shoes still seem ok. I like the way old Yanmars were designed to be owner maintained.
And a comical picture to imagine: When I test-drove the YM240 I tested the brakes with a hard push at full speed and darn near looped around in a circle. Seller said 'I forgot to tell you don't use the left brake. It doesn't release. Just drop the loader bucket to stop'. I wished he had told me sooner.
   / YM276D Brakes
California,
Thanks for the reply; you're a fountain of knoledge and quite the gentleman. I plan to go to the farm tomorrow and look at the tractor and possible work off the shoes. The brakes on it have left a lot to be desired for some time......to say the least. The 276D is in a garage so it's a great spot for working on it, but it's a bit tight toward the wall. I am also considering updating the seat on it because it's cloth. Apparently it didn't rain where the previous owner lived.
   / YM276D Brakes
I started on the brakes today. Took off the tire and removed the cotter key/pin to disengage the brake rod. The shaft isn't budging even a fraction. With the shaft not moving, is it safe to attempt to remove the cover? I don't want to break the cover or any other parts. Here is a picture of what is visible with the tire removed. You folks who do this job with the tire on must be contortionists.
   / YM276D Brakes #5
That's more elaborate than my old-school YM240. After taking out the cotter pin I was able to put a big Crescent wrench on the naked lever, to force it to 'disengage' position. Here's a photo (from my recent axle housing replacement project) showing its simplicity. Can you get a Crescent wrench or pipe wrench in there to rotate the lever?
I think putting the brake pedal at its highest position then rotating the lever until the cotter pin can slip in, might indicate where the lever should be when disengaged. Or the sweet spot where the shoes are fully released, may be a little beyond that position. Good luck with this!
   / YM276D Brakes
The cotter pin has been removed and the lever is "naked." A pipe wrench or Crescent wrench will most likely work....a pipe wrench more than Cresent most likely. Your advice on placing the brake pedal at the highest point seems spot on and offers a good approach.
If I am looking at the photo you provided, you have the axle off but the brake is still in place. I need to watch the Hoye video again.
   / YM276D Brakes #7
That top nut is also part of an adjuster cam for the other end of the shoes (link below to a similar part for reference but not the exact one for your tractor). If you are lucky and that top cam has been adjusted out and it is not froze also- you might be able to loosen the shoes off a little bit that way also. Sort of a long shot but a pretty easy thing to try.
Brake Cam Pin: Yanmar Tractor Parts
   / YM276D Brakes
Will it be better to try moving the arm with a rubber mallet, hammer, or some wrench? I am guessing this will take some time to remove.
   / YM276D Brakes #9
Yes. The brake drum inside that cover is driven by a smaller countershaft that is forward from the bullgear. (The big gear at the inner end of the axle).
Whatever works! Start gentle, increase force as needed. I expect a big pipe wrench could move it, worst case, but its likely not stuck that severely.
Aaron - Wow you guys have Everything!
   / YM276D Brakes
I completed the following steps:
1. Removed the brake linkage.
2. Tapped the brake lever back and forth so it's now able to move with a small pipe wrench.
3. Removed the 7 bolts holding the brake cover in place.
4. Wedged a flexible putty knife around the entire perimeter of the brake cover which sliced the gasket.
5. In the area near the upper back, placed an extremely thin bladed straight slot screwdriver in place (can't load pictures for some reason).
After doing those things:
1. When moving the brake lever, the brake cover rotates about five degrees back and forth. The brake cover won't rotate more because it contacts parts of the frame.
2. The cover remains extremely tight.
Moving forward:
1. I don't want to break anything.
2. Would you recommend hitting the lever like in the Hoye video? It looks like a dead-blow hammer was used.
Other duties at the farm came into play including burning off a large pile of debris and performing mechanical work on the wife's 1965 Mustang getting it ready for the season. I didn't mind that because her car now isn't taking space in the Yanmar garage.
