Hoe and toter
   / Hoe and toter #1
cleatus
Gold Member
granbury tx
sears suburban
Been playing with some aquired inventory and old stock. First the toter was put together to prove to myself that old chaindrive tranny from mower would motivate a rear diff.
   / Hoe and toter
Next I started building a backhoe loosely following free plans. When I say loosely I meen that the sizes of materials must match what I have in inventory. As you look at pic's notice the nice cuts from my skill saw.
I used 1"x4" and 1/2" plate for pivot and swing, the tubes are 3 1/2"x4 1/2" and all pins are 1 1/8".
   / Hoe and toter
The bucket is made from 3/16" plate that I bought as scrap at .32 per lb.
It is 11" deep by 18" long and 15" wide. Here's the pic's.
PS this is as far as I've gotten on the hoe in 16 hours of work. More to come.
   / Hoe and toter #5
Nice shop.:D How about a close up of the steering assembly. Will the hydraulics have it's own power source?
   / Hoe and toter #6
Yea, that doesn't look like your typical steering sector.
David from jax
   / Hoe and toter #7
Nice work on the bucket. How did you bend the 3/16 to form the contour around the sides ? I have a 16" but would like a 24". The price they get for them is quite high. This may be a great alternative.
   / Hoe and toter
Joe, If you look again at pic bh16 you will see it's sitting on 2 channels and was tacked down on back side as viewed with plate to be bent standing up. I hung a chain hoist on top with chain hooked down to support under channals. Pull the chain and it will bend. I tacked as I was bending to keep everything where I wanted it.
Here's a shot of the v-belt steering.
   / Hoe and toter #10
either he is going to use liner motors for the hydraulics or hes just useing them to protype with.....
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
EZ-GO Electric Golf Cart (A55853)
EZ-GO Electric...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
5240 (A47477)
5240 (A47477)
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
