HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-20-2007, 07:38 PM   #1 (permalink)
dfkrug's Avatar
Default Diesel fueling made easy (easier, anyway)
I don't buy a lot of fuel, but I learned years ago that I hate to
lift fuel cans and pour then into the filler on my tractors. I have
seen several threads about this and how tractor users preferred
to do it.
My current solution is not ideal, but it is a great improvement. This does
not apply to you guys who buy LOTS of diesel, of course.
What I did was take a Jerry can and make a cap with a welded-on
tube so I could use air pressure to fuel my tractor. The cap also has
a schrader valve stem with the core removed. Finally I bought a used
fuel nozzle at the flea market, and I removed its anti-overfill valve.
I can now stick the nozzle in the tractor, lock it ON, apply air pressure
with my air hose, and put almost 5 gallons in the tractor in about 10
seconds. No more lifting and spilling.
I can easily lift and carry a full can to/from my truck whenever I need to
get more.
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 06-20-2007, 08:04 PM   #2 (permalink)
Elite Member
Default Re: Diesel fueling made easy (easier, anyway)
Interesting idea.
I really miss the old plastic jugs with the flexible rubber hose. I could rest the jug on the FEL arms and tuck the rubber tube into the filler. Now with those rigid plastic supposedly environmentally friendly things I need to support all that weight and it's very difficult to avoid spillage. The rigid spout on my gas can is so fat it barely fits into my chainsaw so again there is generally much spillage involved.
Pete
__________________
Kubota L4630HST, LA853, Farmi 501 winch
Kubota KX121-3S, angle blade w/ float, hydraulic thumb
BMW R1200GS Adventure Rider
www.GatewayToVermont.com
Boondox is offline   Reply With Quote
Old 06-20-2007, 08:23 PM   #3 (permalink)
Elite Member
wushaw's Avatar
Interesting idea
I use the 5gal plastic Blitz jugs and just lay it on the hood with the bent fill tube in the tank and let the hood do all the work, works for me.
wushaw is offline   Reply With Quote
Old 06-21-2007, 10:42 AM   #4 (permalink)
Elite Member
schmism's Avatar
Send a message via AIM to schmism
im fairly shure your heater hose isnt going to stand up to the desiel fuel for long..... But nice idea!
__________________
Steve - TC33D 4x4 FEL, dual rear remotes with toys
schmism is offline   Reply With Quote
Old 06-21-2007, 10:59 AM   #5 (permalink)
Gold Member
HELLO TO ALL,
you put the fuel into the tractor without a filter?
i use a funnel that has a fine strainer, and was
shocked at the debris that collects in there.
accordionman
wlbrown
accordionman is offline   Reply With Quote
Old 06-21-2007, 11:08 AM   #6 (permalink)
dfkrug,
Were you a race driver in a previous life????????????????
I have visions of a tractor making a pit stop, and 15 seconds later, being back on the "track".
Neat idea though. I sure wouldn't do that with gasoline, but diesel should be fine.
ron
RonR is offline   Reply With Quote
Old 06-21-2007, 01:09 PM   #7 (permalink)
bjr
Gold Member
Air??? Air compressor, or extra air tank? How do you get the pressurized air? It works for you and that's all that needs to happen. I'm just curios is all about the amount of equipment needed to get the pressurized air. bjr
bjr is offline   Reply With Quote
Old 06-21-2007, 01:44 PM   #8 (permalink)
Elite Member
scott_vt's Avatar
Quote:
Originally Posted by accordionman
HELLO TO ALL,
accordionman
wlbrown
Afternoon wlbrown,
On my MF 1040 theres a fine mesh filter inserted into the top of the fuel tank, that does collect some small debris after time. The only problem with it is that you have to fuel slowly or it will run over ! The tractor also has the site bowl and an inline spin on filter. I generally get two 55 gallon drums filled and then transfer to a 2 1/2 gal can to fill the tank. Very seldom do I burn more than 2 or 3 gallons at one time.
BTW I just have a simple crank pump for transfer.
__________________
scotty
,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
scott_vt is offline   Reply With Quote
Old 06-21-2007, 01:51 PM   #9 (permalink)
heymack's Avatar
...and for those with bigger needs:
http://www.tractorbynet.com/forums/o...fuel-pump.html
heymack is offline   Reply With Quote
Old 06-21-2007, 01:58 PM   #10 (permalink)
Super Star Member
Egon's Avatar
As the link states in some of the responses! Pressuring up a non pressure rated vessel with air could be a disaster in waiting.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.30428 seconds with 9 queries
