Results 1 to 10 of 48
09-22-2011, 08:05 AM #1Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
john deere 260 backhoe ripper
I've just completed the first pass design for a backhoe ripper I'm getting ready to build. I would like opinions on it before I go into production. The goal is to build a better ripper than the brotek that everyone seems to be using for the JD 260 backhoe. I want to be able to cut through roots up to 8" in diameter. To do this I have added large teeth on the back side, a tool steel tooth on the bottom, and a 60 degree knife edge on the front. The pin dimensions may have to be altered some. The mounting ears are 1/2" mild steel and the ripper shank is 1" thick. I did not draw the pin bushings yet because I haven't taken any measurements from my backhoe. It's currently at a job site.
I put a cutout in the middle to give myself something to grab onto that wouldn't be sharp while installing or moving it
I think it will weigh about 100 lbs when finished.
09-22-2011, 08:30 AM #2
Re: john deere 260 backhoe ripper
I like the design so far. I'm looking for something to put on my L35. Some of the one's I looked at had a plate on the backside to prevent sinking in the dirt when you curled and to act as a scoop when you needed to move some dirt. You might want to do that. Will the tooth on front be bolt on or welded?
09-22-2011, 09:11 AM #3Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
I'm thinking about using hardox 400 instead of tool steel because I have a local shop that can weld it. Tool steel seems to take more care than the hardox stuff, but I don't know how much it will cost. Another idea is to get a scrap cutting edge from one of the heavy equipment repair shops and cut it to fit, then weld it. I definitely want it welded on.
09-22-2011, 10:22 AM #4
From what I've found you will want some sort plate along the back side of the tooth to support the ripper when prying. Unless the 260 and a huge backhoe.
Check out this design.
http://www.tractorbynet.com/forums/a...r-my-bh92.html
Wedge1967 Ford 4000, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple.
09-22-2011, 02:17 PM #5Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
I added a pin on scoop for the rear. It detaches just like bucket pins. I also stiffened up the mounting pins and moved them forward to allow the tractor to grasp larger objects with the thumb and also to keep the linkage / cylinder end out of the dirt.
09-22-2011, 04:07 PM #6
Dont know when you plan on starting to cut metal, but let a few more besides me comment.
The only other thing I'd change/add is the horizontal plate that the gussets are welded to.. I'd make that and inch or two wider then needed, then use this as a lip to rest the ripper on for a support frame for storage and mounting. Having this thing sitting stable with hooking up to the backhoe will save hours in the confessional. dont ask how I know.
09-23-2011, 01:41 PM #7Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
I'm also going to build a pin grabber so i can switch buckets faster. This should make the stand unnecessary. I'm cutting material on the 28th of September with a waterjet.
09-27-2011, 10:20 PM #8Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
I made some more progress tonight refining the design. The hardest part was drawing the backhoe boom and dipper! I added a second optional pin hole for maximum ripping force and less articulation. I also angled the ripper a little to make it fit better without hitting anything. The big box on the dipper stick is a stand in for my north star weld on thumb. The cutouts on the ground represent 1 foot each, so the reach is about 8 feet. The boom is mounted at the same height as my backhoe sits while on its tires.
09-28-2011, 01:31 PM #9New Member
- Join Date
- Feb 2011
- Posts
- 19
- Location
- PA
- Tractor
- Deere 4310
What software are you using to do your design work in? Looks good. Let us know how it goes.
09-28-2011, 02:23 PM #10Platinum Member
- Join Date
- Jul 2007
- Posts
- 709
- Location
- WV
- Tractor
- John Deere 1026R
I'm using alibre design professional. It's not as fancy as solidworks or inventor, but it's still pretty good, especially for the money! Alibre - Affordable 3D CAD Software, CAM, Rendering, and Document Management Software
I'm cutting at the shop now.
Similar Threads
New John Deere 47 48 49 Backhoe Buckets
By jemmy3 in forum Private Party Ads ArchiveReplies: 3Last Post: 06-17-2011, 09:33 AM -
John Deere backhoe
By farmboyZ in forum Buying/Pricing/ComparisonsReplies: 1Last Post: 04-22-2011, 05:09 PM -
4X4 on John Deere backhoe
By dodge man in forum Construction EquipmentReplies: 6Last Post: 02-28-2011, 10:32 PM -
Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
By FRIZ in forum Buying/Pricing/ComparisonsReplies: 6Last Post: 07-16-2009, 04:03 PM -
Backhoe John Deere 448 Backhoe
By mitchell3720 in forum AttachmentsReplies: 0Last Post: 03-04-2008, 10:40 PM
