</font><font color="blue" class="small">( Are you sure that you didn't send that to me and I welded it? It sure looks like my welding!! I do need to make the same thing, give me some details on the Cat 0 end of your hitch. I have a plow like that and would like to use it. Thanks, honestly, I don't weld good enough to comment on someone else's work- if it holds, who cares. )</font>
I basically started off with a manual sleeve hitch that was mounted on the MTD gaden tractor. I cut the arm off the side that the MTD used to raise and lower the hitch and mounted it on top, welded that and a bunch of braces on it and that was pretty much all I did. Oh and then (after I was done of course) I found a brand new top link bar off of a john deere in my garage, that the previous owner had left up in the rafters.
I will take some close up pictures and send you the link If you would like me to
