Buying Advice new here looking for some advice
   / new here looking for some advice
Thomas,
Thanks - I have not made that one yet. Heading out to the Kioti and Kubota dealers today to get some learnin done.
What do you think about the Backhoe option here in the Granite State and also, how about the cab?
Thanks for your thoughts.
   / new here looking for some advice #12
Thanks TripleR.
How does a cab rob HP?
Added weight and the AC though it is not great. We were going to go to a 4240 instead of a 3940, but found a good used L5030 HSTC. We do have a M8540 HDC and Massey Ferguson 375 if more power is ever needed, but so far it hasn't. We often use the L5030 and M8540 together and both work really well together.
   / new here looking for some advice #13
TripleR, have you had any problems with the 4wd on the massey with those mixed tires?
   / new here looking for some advice #14
Ductape hit nail on the head w/backhoe advice..always going to be something needs moving,re sharping etc. etc.
Are you considering 3pt hitch or sub frame for back hoe?
Cab always sweet thing for those 6 months..many style/model cabs to choice from,would you want to remove cab for warmer weather?
   / new here looking for some advice #15
No we haven't, my father in law had it set up that way when he bought it new in 1986 and much to my surprise, it worked so well that when we had to replace the tires, we went with the same setup.
   / new here looking for some advice #16
We have a similar property albeit a tad larger (82 acres) mostly treed with one 9 acre field that has not been plowed in a few years. I already owned a Kubota B20 TLB when we built last year and it of course has done a ton of work for us. I am however considering a larger tractor in the 40hp range. Due to our stones and trees plus some drainage ditch work needed, I have to get another BH. I have looked at cab models at both Kubota and Kioti and decided due to the amount of work in the bush, I would likely break a few windows and that is a lot of dollars. So it's no cab for me but I do agree, it is nice luxury for blowing snow but I'm a Canuck and can handle it. The implements I have already is a bush hog/rotary cutter and snowblower. I need a boxblade and either a tiller or plow & disc as we plan on planting our open field this spring. Would love a grapple too as they are awesome for clearing brush and trees but they are very expensive and I can't get everything at once! Check out Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements. as they have great videos to help learn about all those wonderful toys.
I would suggest you get a list of all local dealers and some a little bit further out and visit each if you can. Try out each tractor in the size/range you are looking at for fit and finish. Ask A LOT of questions and get a feel for the dealer and whether they have good service as this is important when you need it.
   / new here looking for some advice #17
Boomr,
That sounds great. You have a lot of work to do! You are right a 40-45hp tractor will work great for you. Set your budget and figure what is required now, and what you can wait on. Look at used tractors on eBay and tractorhouse.com ( that will give you an idea of reasonable but slightly high prices). The older the tractor, the less features it will have. If used, try to get something with less that 2000 hours that's clean and maybe kept indoors.
You can't beat a cab, and I have never heard anyone say I wish I didn't buy a cab.
I own or have owned Kubota, McCormick, Farmall, IH, Kioti, New Holland, and Deere. You will find many good options in new tractors at each one of these. Currently, in the 40-45 hp arena I have looked at NH, Kioti, and Deere. My preference would be a Deere 4120, or 4320 for what you are doing. They are very close on price, although Kioti will be quite a bit cheaper. The Deere cab is better and quieter and getting in and out is better. Plus, they are made here so you are supporting your neighbor so to speak. I have some concern about getting parts for Japanese tractors. I looked at a Ford 1910 today but parts are getting hard to get to rebuild it ( transmission problems).
You will not regret a backhoe and will come up with many things to use it for. Get a subframe mounted hoe and not a 3pt ( although I have used a 3pt hoe for years). They are more robust and easier to mount and dismount. It's worth spending the money. A thumb is nice but not required if you can't swing it. Same with a grapple on the loader.
You need a post hole digger and a 6 foot rotary mower ( i.e. Bushhog as they are known). A 6 foot tiller is useful but will dig up rocks and hurt itself in new fields. A two bottom plow and disc might be better. You will also need a seeder. To start, a cone style seeder will be fine. Snow blowers are nice, but still expensive even if rear mounted.
Get pallet forks. You will know why almost immediately after you have them.
You can't beat HST. It took a long time to convince me but I agree. It is indispensable for loader work and using pallet forks as well as with mowing.
Loaded tires are a must.
I use a box blade, angled scraper, and rake a few times a year for maintenance. They don't cost much and are useful.
Good Luck and Have Fun!
   / new here looking for some advice #18
If you just bought the property there are lots of things that will take up your dough there.
Stub Service for hydro
Well
Septic System
I had an old farmall with a bucket and tow bar for a long time before I got caught up in getting the fully loaded deal, see avatar for farmall. Take some time with your property and figure out what your first things first are unless you are starting loaded then go for all of it.:D I have used my pallet forks almost every time I switch implements, lol. Just bought a cement mixer that weighed in at 25o pounds crated and came off the truck no problem on the forks:thumbsup:
I have 35.45 acres:
New Holland Boomer 3045 CVT (not gear or HST) with cab and all that comes in the cab, great for snow blowing, love the heated cab.
6' bush hog
Woods BH80X backhoe with thumb
BX 42 Wallenstein Chipper with hydraulic feed
Wallenstein splitter
6' pull behind snow blower
FEL with Quick attach (I figure quick attach is a must)
Quick attach plate with trailer receivers including my fifth wheel
Three point five cubic foot cement mixer
and pallet forks, lol.
Want:
Band saw mill
Grapple Bucket............
Enough with the silly stuff for a long time I had a wheel barrow and shovel you can get a lot of dirt moved by a local guy in a day and you will not have to build a garage to keep your stuff safe, lol, take your time enjoy the process:thumbsup:
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2012 CHEVROLET EXPRESS (A52472)
2012 CHEVROLET...
