Hey everyone.
It has been awhile since I have posted.
I have been consumed with working on the jd 1020D and just recently got her up and running again.
Check out my other thread below that has been a work in progress for some time now. Big shout out to Tx. Jim and others who have helped me on the old girl. Gotta love the old iron diesels.
http://www.tractorbynet.com/forums/john-deere-vintage-tractors/372447-1969-jd-1020-diesel-6.html
Now back to my dozer. Over the winter I took out two of the Bradco backhoe cylinders and had those rebuilt.
They were leaking and just needed some good R&R.
It is relatively dry enough here in Western Wa. that I wanted to take it out last night into the pasture. To work the new cylinders, get to tear out some blackberry bushes, and move some rocks.
Well I made it about 15ft out of the barn before my hi-gear selector shaft sheared at the bottom. This was around 6 p.m. last night. Needless to say I was pissed, but I decided to well look into what the **** just went wrong.
I took the top cover plate off, after disassembling both gear selector shafts. The springs, boots, etc.
I then had to drain all of the transmission fluid to find the end of the shaft that obviously was gone. I needed a long magnet stick to get to it.
Please see the photos below. Can someone help me source this part? Or can I have it welded back up? If I can have it welded/fixed does it need to have that same shape as the low-gear shaft? That tapered end?
What material is this shaft made of?
Thanks for the help in advance!!!
Click on the photos to enlarge them.
