winch for tracked skid steer
   / winch for tracked skid steer #11
Yes, thats a squegee. I always keep a bottle of plastic window cleaner aboard and when I get out to cruise a section I am about to mulch, I liberally spray the door and squegee it off. There is also a cheep parts cleaning brush stuck in the perforated metal that comes in handy, mostly for cleaning around the fuel fill opening.
   / winch for tracked skid steer #12
on machines that heavy i would think snatch blocks would be required at a minumum.
1 block doubles your pulling power, 2 blocks tripples it.
a 10K winch with a snatch block should be able to hang your skid streer in a tree if you wanted (and found a big branch)
   / winch for tracked skid steer #13
elk land restoration said:
does any one have any info on a winch system for a tracked skid steer. Do they go on the front or the back. I got stuck today and really wished I had one. After an hour of shovel work and some logs I got out. Thanks for any info.
This may or may not help, I have a Fecon FTX90L mulching machine, about 16,000 lb, I fell in a stump hole, the other day and had to go out the back window, I hooked the winch to a tree, but I was too stuck. Luckily I had a excavator near by. This is what I did for next time and there will be a next time
1. bought 50ft of 5/8 cable, with eyes and extra shackles. I keep the cable, on top of the machine, tied down
2. bought 2, 10 ton snatch blocks
I figured, with about twice as much pulling power, I might stand a chance, next time.
Another comment, is You need a powerful winch when you get in trouble.
   / winch for tracked skid steer #14
I keep tree savers (2" rope about 15' long) and snatch blocks with both of my CTLs. The ASV has a Warren 9.5 ti electric, and I used to love it. That is until I got my Supertracks with a 15k Hydraulic on a bohemeth mount.
If I had it to do over, I would put a 15k Hydraulic on my truck, instead of the electric, and I would have opted for the same on my ASV.
The Tak is so much better balanced than my ASV, and I drive around my stuck ASV and winch it out with the Hydraulic on the 150.
   / winch for tracked skid steer #15
This is an electric winch setup I built.Works great with a snatchblock.
   / winch for tracked skid steer #16
I wouldn't have believed it if I didn't see it with my own eye's. On TV they had a show with a buried Humvee in sand up to the frame. They attached one end to a tree, and they kept attaching snatch blocks I think it was a total of 6, and I think 8 guys were able to pull the vehicle out and up a hill.
It was military training, in case they get stuck and there is no other vehicle to get them out.
So yes with a lesser winch and a few snatch blocks one would be OK.
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2015 Hustler Super Z VX4 72in Zero Turn Commercial Mower (A51691)
2015 Hustler Super...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
