FEL/ Hooks
   / FEL/ Hooks #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
This post is from another forum; I also plan doing the same on my Kubota B7800 I am interested in the advice & suggestions
I have a L2900 w/FEL and want to add hooks to use for chaining up or lifting with the bucket. I am interested in ideas about wether to weld or bolt the hook on ...and where to put them...likely uses are to secure something in bucket...dragging something...lifting something out of my pick-up...also does having a hook attached to my backhoe bucket cause any problems?
   / FEL/ Hooks #2
If you use the quote function on the toolbar -it makes your post a lot easier to read. When you simply cut and paste- the message is some what degraded.
I have learned a lot on FEL Hooks by using the search function- type in bucket hooks, fel hooks and you will see about 10 pages ;)
Best of luck
   / FEL/ Hooks #3
I installed a 3/8 thick 2x2 angle and 4 hooks on my 3215.
   / FEL/ Hooks #4
Reinforced bucket lip and used three weld-on hooks. Works great.
   / FEL/ Hooks #5
LQPAPPY, did you get your bucket powder coated? It really looks good. :cool:
   / FEL/ Hooks #6
No. That pic was probably with very little use. Just touched-up with the oem kubota paint. It does not look that good now (about 60hrs) and could use another touch-up. But Thanks !
   / FEL/ Hooks #7
You need a Bucket Buddy. Do a search on the forum. Weld a two inch receiver on your bucket. You can use and make all kinds of attachments then.
   / FEL/ Hooks #10
I added hooks to my bucket and all I did was drill a couple of 1/2 holes for each hook. I may be the odd one here thinking that most of these small tractors don't have the power to lift an item that would pull out four 1/2 in. bolts plus the hook through the bucket.
I've tried :D
UNUSED HART BRUSHLESS ELECTRIC RIDING MOWER (A51248)
UNUSED HART...
2006 JEEP LIBERTY (A51247)
2006 JEEP LIBERTY...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
WOODWAY ELECTRIC TREAD MILL (A51248)
WOODWAY ELECTRIC...
2016 INTERNATIONAL LF687 (A53843)
2016 INTERNATIONAL...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
