Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
  1. #21
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,125
    Westminster, MD
    John Deere 4110
    Default Re: So you think converting a Pin-On to QA is Easy!
    Quote Originally Posted by magicheater View Post
    I don't agree with how they reinforced the upper brackets though.
    Why? Have you ever read about or seen one fail? Not me-never.
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    Quote Originally Posted by kennyd View Post
    I have talked with people that have had them bend. Here is how I engineered it. Certainly not looking to pick a fight here.
    Attached Thumbnails Attached Thumbnails So you think converting a Pin-On to QA is Easy!-dscf0679.jpg   So you think converting a Pin-On to QA is Easy!-dscf0677.jpg
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  4. #23
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    Kioti DK35se Hydrostat
    That looks nice, but I could remove that in a few minutes.. Piece of cake!
    now that Kubota thing,,, well it was never intended to come off. Just kidding guys, the real question is why in he!! doesn't all Kubota's come with QA?.. I know I know... money$$. and why was I stupid enough not to specify a QA in the first place
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks.Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  5. #24
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    Well here is the top bar of steel. tacked on only. too dark, not to make excuses (Don are you there?) lest Don think I am a Candy.. um you know... anyway. maybe tomorrow I can finish welding the top and weld on the hooks in line with the loader arms, and paint if there is enough time. Painted it Sunday, all over. but of course did not have the top piece of metal yet..
    Thanks for looking.
    James K0UA
    Attached Thumbnails Attached Thumbnails So you think converting a Pin-On to QA is Easy!-dscf0454.jpg   So you think converting a Pin-On to QA is Easy!-dscf0455.jpg   So you think converting a Pin-On to QA is Easy!-dscf0456.jpg   So you think converting a Pin-On to QA is Easy!-dscf0457.jpg
  6. #25
    Elite Member rswyan's Avatar
    Join Date
    May 2004
    Posts
    3,727
    Northeast Ohio
    Kubota B2910, Simplicity 18 CFC, Cub Cadet 782
    Quote Originally Posted by mwb View Post
    Dad and I did his with 5 inch grinders and cut off wheels (1/16). I think it took two of us about an hour to get the bucket cleaned off
    mwb,
    Thanks for posting the link for your SSQA build - I currently have the pin-type Kubota QA and would like to replace it with an SSQA (one that used a linear actuator for the pin release would be really sweet) .... your project has inspired me to contemplate rolling my own
  7. #26
    mwb
    mwb is offline
    Platinum Member mwb's Avatar
    Join Date
    Feb 2008
    Posts
    614
    Ottawa Ont Canada
    3940HST Montana
    Quote Originally Posted by rswyan View Post
    mwb,
    In the link (in my post) is a link to the original build that I did for my Montana. That post has full drawings, parts list and detailed photos. Here, this is a lot easier http://www.tractorbynet.com/forums/b...t-quick-1.html
    Lots of options out there for QA - just wish that all the OEMs had standardized. I removed my Montana-style QA in favor of the SS. Seemed a shame to ruin a brand new and working accessory but to heck with it.
    Besides, all that grinding, hammering and welding builds character!
    k0ua, one thing I would have done is remove a bunch of material from the center of the weld-on QA plate. This would have given you additional welding edges and reduced weight (ok, maybe not much but every pound counts)
    Montana 3940HST
  8. #27
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    I finished welding on the top plate tonite, I went with 1/4 instead of 3/8, I looked at my
    new Kubota QA bucket and that is all it had on it. I did not get to the hooks. Maybe tommorow
    The continous bead on the back is the most I have ever welded in a single line. I know I
    would not make a pimple on a good welders.... but I was pretty proud of the welds. Its about
    as good as I can do anyway. Rod-US Forge 7018 Size- 1/8 Polarity-DCEP 122 amps
    Welder Everlast PA160 Inverter.
    As for removing more of the center metal, I though about that, but it looked hard and I also though it would add more stiffening in the center, oh well it is a little late now..
    thanks for looking.
    James K0UA
    Attached Thumbnails Attached Thumbnails So you think converting a Pin-On to QA is Easy!-dscf0458.jpg   So you think converting a Pin-On to QA is Easy!-dscf0459.jpg
  9. #28
    Platinum Member BoFuller's Avatar
    Join Date
    Feb 2011
    Posts
    640
    Arizona
    2008 Kubota L3400
    Wow, what a lot of work. I got a new bucket when I got my QA, but I figured I'd slap a plate on the old bucket one day. Maybe it will just be a flower planter now.
    When I got my original estimate for the QA, I asked about them doing the old bucket. They said they would but they wanted $300 to setup the old bucket with the QA plate. I thought that was really high for welding, but maybe it wasn't such a bad price afterall???
  10. #29
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    Quote Originally Posted by BoFuller View Post
    Knowing what I know now, I would do one for $300, because I think I could a better job now with some experience, but let me tell you about half way thru, I was thinking about just forgetting it. Having the proper tools would help, and here is something I would do different : Step 1 cut off the vertical part of the ears either with a good big torch or plasma or big wheel
    Step 2. drill out plug welds with at least 1/2 or 5/8 drill bit.
    Step 3: turn a cutting wheel vertical, and cut in on the "inside" of the vertical "fillet welds" . Leave these welds alone at this step, just get the middle strip of metal loose on both sides, and bust the remainder of the plug welds. now the middle piece is out and you are left with 2 vertical strips of weld under a little bit of the original base metal.
    Step 4: now start cutting on BOTH sides of the fillet and the MIG weld with at least a 4 1/2 wheel and a 5 inch would be better so the angle can be more shallow. Now that you have access to both sides of the weld stack the cutting will be much easier. Note I did not do any of this, but I have thought it out, and I think this is the way to do it.. Bring it over and I will do yours for $250.. so how about that?
    James K0UA
  11. #30
    Join Date
    Feb 2011
    Posts
    640
    Arizona
    2008 Kubota L3400
    I'd gladly take you up on the $250, but it's the 2500 mile round-trip that seems to be a bigger obstacle.
Similar Threads
  1. Bucket Lynch Pin size
    By ERE in forum Kioti Owning/Operating
    Last Post: 04-27-2011, 02:59 PM
  2. Backhoe Backhoe Pin Wear
    By BXTotal in forum Kioti Owning/Operating
    Last Post: 10-26-2010, 11:22 AM
  3. converting back to pin on FEL bucket
    By jmc in forum Kubota Owning/Operating
    Last Post: 10-27-2009, 09:43 AM
  4. Toplink Toplink pin
    By pycoed in forum Attachments
    Last Post: 08-07-2007, 09:04 AM
  5. Kubota Skid Steer QA Question?
    By North GA in forum Kubota Owning/Operating
    Last Post: 05-17-2007, 07:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
