powerscol
First - I want to thank Clipse3GT. He did an install and some fantastic dash work in this thread. http://www.tractorbynet.com/forums/.../349196-2015-gc-1720-led-dash.html?highlight=
Parts list
20" Sirius Professional LED Flood/Spot - https://motoalliance.com/Site.Store....etails&id=1344
ROPS Mount can be found here ROPs Light Mounts These folks used to be under 20" Sirius Professional LED Flood/Spot - https://motoalliance.com/Site.Store....etails&id=1344 They appear to have changed their name or split off. Prices appear to have changed, but the kit I got is very good quality wise.
First thing I did measure up the included wiring harness, taping it to the tractor to determine where everything would fit. The harness comes with a plug to the light bar, about 8' of wire to a relay that is connected to the dash switch I selected. It is also connected to the power wires that has a fuse in line. both of those wire runs are about 3'. Once I determined everything would fit I started by putting the dash switch in. My tractor has a center cover which is plastic. I pulled it and checked for clearance. For my switch I needed about 3". I used the template you can find on the motoalliance site. Dremel tool made quick work. Note - cut inside the template first then widen. The switch does not have much of a face plate to hid any mistakes, so be careful.
First picture is of the switch in the dash. Second is of the tools and third is the backside of the dash with the switch clips in place.
Parts list
