Chain Saw Carrier
   / Chain Saw Carrier #1
hayden
Elite Member
VT
Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
This has come up a number of time - "How do I carry my chain saw on my tractor?". I've been thinking about building this gadget for some time and finally got around to it.
You are all familiar with a bar cover. Well, this is just a wooden bar cover that I bolted to the loader frame on my B2910.
Here are the parts ready for assembly
[image]http://www.tractorbynet.com/forums/download.php?Number=776589[/image]
   / Chain Saw Carrier
Here it is assembled. I used scrap wood, so it's not real pretty, but it works. I like wood for this purpose to prevent damage to the bar and chain.
   / Chain Saw Carrier
Here's the "bar cover" over the chainsaw bar.
   / Chain Saw Carrier
And here it is mounted on the loader frame with a saw loaded up a ready for transport.
   / Chain Saw Carrier
And another view
   / Chain Saw Carrier
Here's how it mounts to the loader frame. It's a bit hard to see, but I used carrage bolts run thru the edges of the wooden cover, the metal straps over the loader frame cross bar. The carrage bolts go thru all three layers of plywood that make up the bar cover to give it max strength.
   / Chain Saw Carrier
Here's the same view but with a bit more perspective. I might have a problem with clearance between the wooden bar cover and the front wheel. If the wheel is turned, and the tractor is tipped, they might collide. Time will tell. Worst case, I'll just raise the whole thing up, but I am hoping to keep the saw as low as possible to limit the thrashing about and resulting stress on the whole apparatus.
   / Chain Saw Carrier
Chain saws are like tractors. Why have one when you can have two!
   / Chain Saw Carrier
And here's the view from the drives seat. I'll probably be complaining about poor visibility in short order.
   / Chain Saw Carrier #10
Nice lookin job. I got one similar mounted on my logging winch. You must be in some real rugged country to have all 4 wheels chained up.
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
Rhino DB150 (A57148)
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A56435)
2018 Cadillac...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2019 GALYEAN...
