B3030 Position control lever stop knob redo
   / B3030 Position control lever stop knob redo #1
danbuf
Member
Buff NY
Kubota B3030, ford 860, & Deere 445
I didn't like position control lever stop knob on my B3030, so I whipped up a new one on my lathe. The original is difficult to get at.
I added a hard rubber/plastic washer under the knob to cushion the contact with the plastic frame assembly.
Works great and is easy to adjust now..
Attached is a before, after, and comparison of knobs..
Dan
   / B3030 Position control lever stop knob redo #2
That looks real good. I know what you mean about it being hard to turn. I put a couple of extra washers under mine. It helps, but could be better.
   / B3030 Position control lever stop knob redo #3
Dan
I know this will sound silly, but, you should patent that and market it. I'm guessing you could sell more of them than you would ever imagine!!!! I can see a box of them on the parts counter at the Kubota dealer!!! :)
I'll be the first customer!!! How much for one to fit my B2910???
   / B3030 Position control lever stop knob redo #4
no kidding! i could use half a dozen (5 for my FIL as a gift, some of his are missing completely)
   / B3030 Position control lever stop knob redo #5
Toolguy how about a marketing name like stop that? :rolleyes:
   / B3030 Position control lever stop knob redo #6
Probably not being politically correct here (What's new) but, the little Japanese guys that designed the stock knob probably thought it worked pretty good. With our big American fingers it is not as easy get a hold of it and tighten it.
   / B3030 Position control lever stop knob redo #8
schmism said:
hate to spoil it for ya... but their is an off the shelf knob almost exactly like that for about $5.
even "ratchets"
Ratchet/Ball Knob - Rockler Woodworking Tools
Dang It Danbuf!!!! Someone beat you to it, sortta!!! I still like yours though, it's a lot more stylish and durable!!! Probably be hard to produce for $5 each though!!! :(
I was aware of commercial knobs that could be adapted.. But, what fun is that? :eek:)
Might be tough to find just the right knob with 6mm screw, etc..
I love using my shop equipment and, mine was designed around the application.. So it fits perfectly..
So in winter months when I can't get any seat time, I can get all the shop time I can squeeze in...
Thanks for heads up though..
Dan
   / B3030 Position control lever stop knob redo #10
Yes, that's what's fun about it...making your own "stuff". That's a nifty little handle you made custom...only 1 like it in the world now. Very nice job.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
Brush Bandit 200UC (A52377)
Brush Bandit 200UC...
TRUCKING INFO (A50775)
