warhammer
Gold Member
That is good quality and does not cost an arm and a leg. Not having good luck with the $100 pump from TSC and really do not want to lay out $309 for a "silver" pump if I do not have to.
What are you pumping?
Are both the pump from TSC and the "silver" pump (??) roller pumps? PTO driven?
Might could help if we had some info.
warhammer
I would (and did) switch to a Shurflo pump. Much less maintenance than when I worked with the PTO roller pump.
Yes both are from TSC and the type is PTO.
The pump I have is the Hypro. I used it once several months back spraying 2-4D flushed several gallons of clean water through it and then a half cup of oil and rotated it severl turns. It was locked up solid when I went to use it this weekend.
I have taken it apart and cleaned it up and reassembled. Don't know yet whether it will work. I need to spray Round Up on this usage.
