repete
I would definitely look at your linkage from the column to the gearbox. Have someone move it while you watch it. Look for any slop.
I do not think the fluid would have a lot to do with the hard movement. Is it binding against the body?
Is this tractor used regularly (weekly)? Stored indoors or at least covered? Lubrication may be the key here. I lubricate my linkage (all pivot points) probably once a year with motor oil. This is a good time to do it as we head into winter to avoid rust.
