The HP/Cutter Width Rule-of-Thumb
   / The HP/Cutter Width Rule-of-Thumb #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
First, my rationale for this post. It's raining so I can't work outside and I fear that the Missus will assign me household chores if I do not appear busy at the keyboard.:)
The rule-of-thumb that each foot of rotary cutter width requires 5 tractor HP is often cited here. I thought I would test the rule-of-thumb against a manufacturer's recommended minimum HP requirements. I selected Woods rotary cutters for the test for no particular reason, and used the information from the Woods Web site to construct the attached chart. *
Woods Equipment Company
The cutters with black symbols are 3PH-mounted models and those with red symbols are either pull or semi-mounted models. When a model was available as either a 3PH mounted or pull type, I used the pull model data.
How does the rule-of-thumb perform? You be the judge, but I would recommend the rule-of-thumb only as a very rough first approximation.
Steve
* I'm not bored enough to expand the chart to include other manufacturers.
  • rule-of-thumb(2).pdf
   / The HP/Cutter Width Rule-of-Thumb #2
I have a 5' on a 25 hp Kioti, and a 17 hp walk behind with 3' cut, both work good. I don't want to do the dishes either.
   / The HP/Cutter Width Rule-of-Thumb #3
I have a 70 HP tractor and an 8' JD MX-8 semi mount. Runs the mower like it's not even back there-through very heavy field grass.
Will get a 12' folding batwing someday.
   / The HP/Cutter Width Rule-of-Thumb #4
Steve
Can tell you were a statistics/econ professor. Sorry i just thought it was funny and had to comment
I was going to test HO: alpha = 0, beta =5 versus the alternative that at least one equality fails and report the results. However, I might be banished from TBN if I do so.:)
Steve
   / The HP/Cutter Width Rule-of-Thumb #6
You really DO have too much time on your hands... let this be a lesson, next time buy a tractor with a cab so you can mow in the rain.
Sean
