Power Steering Hydraulic issues after clutch repair
   / Power Steering Hydraulic issues after clutch repair #1
MichKubota
Holly, MI
Kubota L2850 Hydrostatic/ Deere 5410 w/loader
OK, I posted before and thought this issue was fixed but it is intermittent.
New hydraulic filters were put on about a month ago and all the hydraulics worked correctly.
However; just after a clutch job (hydraulic lines had to be removed for this) tractor has two new symptoms:
1. After starting tractor, power steering takes about 5 seconds to begin working.
2. Sometimes, power steering doesn't work even after 5 seconds. The tractor has to be turned off and restarted.
When it is not working I have removed hydraulic out line from pump and no oil is coming out. So this has me believe it is a hydraulic pump prime issue.
But the hydraulic pump assembly is made up of two separate pumps. One pump is for the 3pt hitch/loader and one for the power steering and GST transmission. Both of these pumps get hydraulic oil from same input supply line.
   / Power Steering Hydraulic issues after clutch repair #2
Didn't see your other thread but it sounds like you have a suction line leak. Have you tried tightening fittings more? If they are compression style fittings they can be a bear to get to seal after they have been disturbed.
Kim
Thanks KWentling for your thoughts.
Yes, All the hydraulic lines use compression fittings. I will verify they are all tight. If a line wasn't tight enough wouldn't some leaking of hydraulic fluid be seen?
   / Power Steering Hydraulic issues after clutch repair #4
That's what's tough about finding suction leaks. They are leaking air in, not oil out. And air can leak in where oil won't leak out, unless under pressure.
Kim
KWentling - Thanks. Good thing the input lines to the pump are rather limited and number of connections are few.
I have a sneaky suspicion that this rubber hose into bottom of pump is issue.
If tightening the other joints doesn't help I will order this hose and replace.
Thanks
   / Power Steering Hydraulic issues after clutch repair #7
Bob if your pump is mounted on top of the filter housing, don't overlook the o ring between the two.
Lee - After checking all connections if nothing is found, the pump will come off for inspections. I will not forget to check that O ring. Thanks
