OP
Chain Bender
- Joined
- Feb 25, 2011
- Messages
- 249
- Tractor
- Kubota L3200
I
I'm not much with all the picture posting, but I'll try to take some pics this morning before I go to church to show the "poblems" I have encountered.
Bottom line is that with the configuration the disc is sold in it is impssible to adjust the gang set without completely removing a 5/8 inch bolt (adjustment pin) and loosening a pair of 5/8" bolts on each interior gang. Then and only then can you move the gangs. Then you can drop the center (adjusting) bolt back in, re-tighten the two bolts on the gangs, then tighten the center bolt. Repeat this for the other set of gangs if you wish to adjust them too.
Oh, wait a minute. There's this problem with a 3/8" thick piece of metal bumping up against the main frame preventing the gangs from moving more than one adjustment hole.
Maybe I'm the only one to experience the problem, but I doubt it.
CB
XXXXXXXXXX
Here's some pix of the design flaws:
As you can see in this picture, the gang frame is butted up against the main frame, prohibiting any forward adjustment of the gangs, even if all the bolts are loosened to the point of falling off.
a downward picture of the limited adjustability caused by the main frame and gang flange hitting.
Here are pictures of the flat bar welded on the flanges so tight up against the center rail of the frame that you can't move/change the gang setting, even using an 8# hammer!
