CowwFace
Gold Member
- Joined
- Jul 19, 2009
- Messages
- 367
- Location
- Conifer, Colorado
- Tractor
- Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Well I've seen it posted here several times and it thought I was being so careful BUT!! 111 hours on my baby and my first battle injury.
I was moving stacks of willow branches, ranging from 6 to 10 feet in length and about 4-6 feet high, to more dry ground to be run through a chipper. All was going great until I noticed the temp gauge creeping up (My Kioti temp never varies from the 2 small dots on the gauge) ... Sure enough it kept getting closer to the Red so I shut the motor off ... Looked for leaks .. none.. checked oil it was fine, Hydro fluid good ... let things cool off and started the motor back up.. temp was in the normal range ... drove across the meadow for another load and temp crept up again .. I was thinking thermostat or water pump .. then I opened the hood and took off the side panels ... and my fan was broken ... undoubtedly by a rogue stick getting up there somehow?? I did not notice it was broken the first time I looked because engine was running ... but with the engine off .. pretty obvious.
My radiator got kissed a bit, but no leaks so I think I got off pretty easy with just a $30.00 fan replacement ... dang try to be so careful and this stuff still happens!
Tractor on
Tractor on
