NHmitch
Hi,
I have a general question if anyone knows the answer, because I have not been able to find a ton of information in my repair and operators manual. I have not changed the hydraulic fluid in the rear of the tractor since I have owned it. The manual says that there are three drain holes, and it takes 13.7 liters? This seems like a lot, but it must be correct. Also, I have just added fluid to it over time, and I may have over filled it because, when I take the dipstick out that is next to the shifter, to check the hydraulic fluid level, fluid pours out. Also, when I lift anything of significance with the three point hitch, fluid comes out from the boot area of the shifter. How often should I change the hydraulic oil, and is it bad to have too much oil in the gear case? Thanks for the help!
Mitch
Mitch
