An idea came to me as I was removing the coil and starter so I could gain access to the rivets holding the engine's data plate in place. Since my goal will be to simply move the tractor outside so I can sandblast it, then move it back into the garage so I can paint it, I could use the starter to move the tractor.
Getting the tractor out of the garage could be done by having someone push while I steered and applied the brakes to stop, so I would only need to use the starter to move it back into the garage. The tractor would only need to be moved about 15 feet, and placing the tractor it's lowest gear while leaving the spark plugs out to reduce the load on the starter, should get the job done without any damage to the starter. At least in theory anyway.
Granted, I'll have to wait until I've finished rebuilding the cylinder head before I can move the tractor outside to sandblast it, but using the starter to move it when the time comes is so simple it just might work.
