Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,135
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
According to the shop manual (looking at it now) for the Continental Z-145 engine, the compression ratio is 7.1 to 1 (not 6.5 to 1), and the compression for all cylinders should be between 145-160 PSI for a warm engine cranked at 150 RPM. However, the shop manual didn't specify if the compression values were wet or dry, so I'm assuming it means dry.
Now that I think about it, oil combined with carbon, was likely the main cause for the higher than expected compression readings, and would also explain why there wasn't much difference between the wet and dry compression readings. The higher than expected compression readings could also mean that the lower half of the engine is in great shape, despite the problems with the upper half of the engine, mentioned previously.
In any case, I plan to perform another compression test after I've reassembled the cylinder head, and get the engine running again. I could be wrong, but I believe I'll see a greater difference between the dry and wet readings, but judging by the condition of the pistons and cylinder walls, I don't expect to see much change from the previous compression readings.
The specs are given dry and also assume the test is conducted at an ambient pressure of 14.7 psia or 29.92 in Hg. The compresion presure level of pressure needs to be adjusted for ambient pressures due to altitude or the local pressure where the test is conducted. The test should be conduced on an engine at operating temperture with the throttle plate wide open and the air cleaner disconnected.
I didn't realize that the CR was 7.1. That alone will cause the higher compression pressures you recorded. Nonetheless, the compression numbers you have wet and dry don't indicate any major problem with rings and valve sealing. Your numbers seem within the nominal range wet and dry. The fact that the wet only increased by 5 psi is indicative of good ring and valve sealing. Worn rings would have seen a greater change in pressure from dry to wet.
