JC,
I have pulled the water pump and ordered a replacement. View attachment 277058
I'm trying to attach photos. I may need some help with including photos if I can't figure it out.
I was able to include the picture. This is the back of the water pump opened up. Shaft is bent. I doubt that this pump would be easily rebuildable. The other 2 photos are of the nut that won't snug up on the injector pump mount. Do you have any part numbers for radiator hoses that will fit this tractor. Thanks, Jerel
Thanks for the parts info. I'll try to remove the pulley and see what is in there. It didn't move when I tapped on it, but I didn't get real aggressive. Do you think that trying to hitting the shaft from the impeller end would work?
Any thoughts on the injector pump mounting bolt that will not tighten. When I try to tighten the nut I can see that the bolt is turning. View attachment 277068View attachment 277069View attachment 277070View attachment 277071
