WANTED: International 254 4wd Center Axle Housing
   / WANTED: International 254 4wd Center Axle Housing #1
DaLi220
I'm looking for a Front AXLE (Center Part) Housing ASSY, RH, Case IH part #1273219C91. Same as International 244 & 255, May be interchangable with Mitsubishi MTE2000D & MTE1800 tractors. Without it my tractor is worthless...I really need this part! If you have this part or complete front axle, please email me! Thanks! davidrlittle@yahoo.com
  • axle%20part[2].pdf
   / WANTED: International 254 4wd Center Axle Housing #2
I did the same to my 244. Took everything apart, cut out the break, heated up the housing, welded on a tube I machined and then covered everything in a welding blanket for a slowwww cool down. Turned out great! Traded for a Deere 3320 some time later. Loved that little 244.
   / WANTED: International 254 4wd Center Axle Housing #3
OrangeJbird,
My RH side front 4WD axle housing on my IH 254 broke in the same way as your previous IH 244. Can I ask what type of welding method you used? Was the tube you added made out of cast iron--same as the housing cast iron? I have exhausted all options, this part is not available anywhere. Many thanks!!!!!!!
