SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,160
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Sounds like the prior fixSeems most of these post are from 2009, about the time I had the clutch replaced in my Farmtrac 665. It had about 300 hours on it at that time. Now, at 825 hours the clutch is toast again. Same symptoms as the first time I had trouble, clutch will not dis-engage. Not like a clutch worn out but just locked up somehow. I thought I'd do a little trouble shooting and slipped it into lowest gear while running at the lowest possible RPM, then while at higher rpm, moving down the road I engaged the clutch fully then put on the breaks. The tractor stopped and kept running, sounded bogged down but still it convinced me that the clutch was not just stuck together.
I need to find a dealer, anyone know a dealer near Victoria Texas that will work on this Farmtrac?
larry
