Rockshaft Pin Removal -- 4410
   / Rockshaft Pin Removal -- 4410 #1
jeffinsgf
Springfield, MO
JD 4410
I've done some damage to the pins in my rockshaft. I took the nut off the inside, but it doesn't seem to want to budge. It appears to be threaded into the rockshaft, but I couldn't get it to budge, even with a reasonably big cheater bar.
Is it threaded into the rockshaft or is it a press fit?
Any help on getting them out?
Well, here I am answering my own thread...
The pins are tapered. Theoretically a couple good smacks with a hammer should pop it out. Have the replacement pin in hand now, I'll let ya'll know how it goes tomorrow.
   / Rockshaft Pin Removal -- 4410 #3
Not really sure what part you are talking about.
   / Rockshaft Pin Removal -- 4410 #4
I believe he is referring to pin #20. They are tapered and once the nuts are removed, a good whack with a 3 lb hammer should pop them out.
That it did. Easy peasy.
   / Rockshaft Pin Removal -- 4410 #6
I was thinking off of shaft 14. Picture is worth 1000 words. Glad you got it fixed!!
