Back blade with angle hydraulics
   / Back blade with angle hydraulics #21
Bison sells a "kit" for each function up to three on the rear blade, the kits are $250 each. I can beat that pretty easy sourcing cylinders/hoses and fittings locally. Some of the stuff I already have laying around though.
   / Back blade with angle hydraulics #22
I just got the bison blade all put together and plowed out the driveway, this sucker sure plows! I don't think the tractor can hurt it either.
I put it all together by myself with no overhead lift, but two people would be better!
I got the XHD model, no hydraulics as yet so I need to get off and move the pin - but I've been doing that for years and years with the old blade.
pretty sure this takes all 3" bore x 8" stroke cylinders, 3 of them total.
   / Back blade with angle hydraulics #23
I bought a Land Pride RB3784 rear blade with the hydraulic angle kit ($275) this fall and i really like it for plowing snow. I haven't plowed any dirt with it yet but I'm sure it will be good. It is a 7' and if you want to reverse the blade u have to pop the cylinder off and lift it over to the other side, (not a big deal) I haven't had the need to do it yet. It is a nice heavy blade (630#)
   / Back blade with angle hydraulics #24
Anyone out there make a rear blade with only hydraulic angle adjustment? I do not need the tilt option etc... checked out everything attachments and to my surprise they did not
I have a Frontier 72in one with hydraulic angle.
   / Back blade with angle hydraulics #26
I wish ET would make a rear blade with hydraulic angle, too. They say someday, but I don't see it happening for some time.
I will be buying something in the spring, but since I won't be using it very much after the first season I haven't pulled the trigger on a Landpride or something with the hydr angle.
Probably will in the end, though.
   / Back blade with angle hydraulics #27
I probably don't need to mention it, since it's already been mentioned, but I will anyways :laughing:
The Landpride rear blade is available with hydraulic angle. I believe the new model is the RB25xx or RB35xx (xx being the length in inches)
Speaking of rear blade hydraulics... I have a whole bunch of goodies waiting for me at home from MtnviewRanch to convert my manual offset to hydraulic offset. Can't wait to try it out :D
   / Back blade with angle hydraulics #28
Have you decided how you are going to operate ALL those cylinders? Dumb question, you have 4 sets of rear remotes. :eek:
LP's economical RB that you can get hydraulic angle on is the 37 series. Bad design though, you have to move the cylinder from side-side whenever you reverse the blade. :thumbdown:
   / Back blade with angle hydraulics #29
Have you decided how you are going to operate ALL those cylinders? Dumb question, you have 4 sets of rear remotes. :eek: LP's economical RB that you can get hydraulic angle on is the 37 series. Bad design though, you have to move the cylinder from side-side whenever you reverse the blade. :thumbdown:
Is that just a 37 series thing? I'm pretty sure on my 40 series it has a mounting hole for the cylinder on both sides, so you can disconnect the rod end, turn the blade, and reconnect using the other hole.
I thought the only difference between the two was the added strength/weight in the frame? Although, I've never seen a 37 series in person.
   / Back blade with angle hydraulics #30
Look at post #23. You will see what I mean and he even mentioned it. Yes I believe that it is a 37 series thing only.
