Yikes! Well pump replaced.
   / Yikes! Well pump replaced. #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
2005 was $2500.
2014 $5,672.34.
500 foot well, 5HP 20gpm pump, motor, and control box replaced. After the job was done I asked what if I put a 10 gpm pump, maybe a 2HP? Would have saved $2,000. Not sure I could tell any difference.
   / Yikes! Well pump replaced. #2
That is one heck of a well set up. Will it actually flow 20 gpm 27/7?
   / Yikes! Well pump replaced. #3
That is an expensive pump if it's just servicing a dwelling
Ag use might need it, but a house? Never!
   / Yikes! Well pump replaced. #4
Holy heck, you had me at 500 ft.
   / Yikes! Well pump replaced. #5
Thats a huge pump for a house a 2hp 10gpm would be plenty. ( depending on your static water level, flow rate etc..) But saying that the price isnt too bad if thats including installation. Just to pull a pump that deep runs $600. To $800.
   / Yikes! Well pump replaced. #6
2005 was $2500.
2014 $5,672.34.
My neighbor just put in a new well last year, 5 inch pvc, 200 ft deep, it cost $4500. I think it is a 1 hp submersible pump.
   / Yikes! Well pump replaced. #8
I'm not sure, but 600' TDH might not even be possible with a 2 HP pump, so you'd likely end up with 0 GPM flow.
   / Yikes! Well pump replaced. #9
I hope they upgraded the electrical feeding it. 5 HP is a whack of power.
   / Yikes! Well pump replaced. #10
Depends on the level of the water in the well. the pump only works against the elevation between point of use and the _top_ of the water. Of course drawdown also comes into play.
Harry K
