mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,093
- Location
- Central NH (God's Country)
- Tractor
- 1984 Kubota B7200D (Sold 2015,) 2005 L39 Kubota, 2006 RTV 900 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle
My 2013 Max28 XL shuttle has less than 4 hours on it. I bought it as a new leftover in NY State. (Tier 3!)
I have not worked the machine other than play move some snow, but immediately noticed the loader seemed especially weak.
The machine has no ballast, in fact the front guard is removed to add a expanded metal grill guard.
The loader will barely, just barely start to lift the front tires off ground.
The Blade my excavator weighs less than 1100 lbs, Just trying to lift one corner with it in float, the Max 28 loader will barely budge it.
My Max 28 bucket will not even break out a good load of soft snow in a pile.
My tired weak smaller Kubota has as much fight, if not more.
First thing I tried was the relief valve on the loader, as it looks it was ever adjusted as there is like no paint marring from wrenching.
Turning the screw in made no difference, nor did two turns screwing it out. It took 3 full turns out on the adjustment screw for me to notice any difference in loader performance.
Therefore my conclusion is the main pump relief is set very low.
That will mean also the 3 pt lift won't be worth anything.
I'd be happy just to be able to be at 90% of advertised rated capacity.
Could someone tell or better yet post a diagram or photo of how to set the mail pump pressure and just where is the pump relief valve located?
I'd very much appreciate it very much, as a old guy with poor eyesight crawling around in the mud is not pretty.
PS: I think I see it hiding behind the loader frame on Left Side?
