Shield Arc
Super Member
If not, you can buy small rolls at Lowe's.
The material looks thin, so it probably doesn't matter. Remember to run as hot as you can handle it!Oh, I have .023 Lincoln wire in now but I also have .030 if I change things over. Do I have to?
Looks like its cracking on the non-drive-chain side (passenger side). Is this correct?
I don't see marks from the square u-bolts in your crack pics. Does yours have that square u-bolt an inch in from the crack?
Trying to get a picture of the forces, to recommend how to brace it up. This is difficult not seeing the item in front of me, so more pictures will help (if you're interested).
At ShieldArcs thinking, I looked at the other side and found the weld there went around the ends of the square tubing on the bottom. This type of weld is missing on the cracked side so my thinking is the welder missed part of the weld.
That was mighty observant of Shield Arc!
