Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,197
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Has no one thought about just putting it back in the jack stand facing the opposite direction and then drag the trailer forward just like you did to bend it the first time. Go slow and have a flagger to stop when it gets straight. If that doesn't work, just fab up a new piece of pipe. You may not want to go stronger because the next time it may break the mounting attachment rather than just bending the foot.
What about doing this but use a screw-type chain binder (or twisted chain) attached to the bottom plate to pull it back straight. If it slides thru then you're done, right?
I wouldn't use heat, you will burn all the galvanize off. Maybe that gets it straight but you just traded one problem for another.
