handloader
Tractor sat up for a year. Tried to start it and turned over good but know start. Cracked fuel rail at injector, middle injector only had fuel. Removed inspection plate on injector pump and the two outboard pumps not raising and lowering. Removed delivery valve spring holder and found that plunger barrel was stuck. Freed barrel and re-assembled. Engine still will not start and crackcase filled up with fuel. Fuel dripping from the top of the fuel injection pump body into the pump side cover and I assume this is where it gets into crankcase. Any suggestions.
