Sawyer Rob
Super Member
Maybe, maybe not. Generally the front wheels spin a few percent faster than the rears, 2-5% or so I believe. That helps pull the front end around so it actually steers when in fwa compared to the traction on the rear.
Fronts do wear faster because of their size, slightly faster rotation & because of steering.
While all of that supports the sales guys case I'm still sceptical that isn't anything other than BS.
SO, this is what the dealer told him
He said the smaller front tires wear faster than the rears and the overall gear ratio gets into balance after the tractor breaks in.
I take it that he meant A. after running things will wear in and the gearing will correct itself OR B., after the front tires wear down, the gearing will correct itself...
Personally, I don't like either answer!!
I call BS on A. and if "B" is true, the gearing in the tractor should have been set closer in the first place.
I can show you a pict. of the "original" tires on one of my MFWD tractors that's 19 years old and the front tires did NOT have to "wear in" to correct the F/R gearing!
I do NOT have to raise the front end, to get it out of gear. Backing up a "little" or turning to one side a bit lets it slip right out, just like all my other MFWD tractors.
AND yes it is geared a bit faster in the front end and works perfectly at a MFWD tractor.
SR
