CobyRupert
Super Member
Ditto on the rollers and spreader bars. Maybe even internal bracing or cabling if there’s a chance you may fold the building in or rip it apart.
How would you hook onto the building to pull it? Chains, straps? Or would you push it?
Any way to get jacks under it and raise it?
Pull it with like LeeJohn and James mentioned. I'm hoping it's an idea my wife kinda forgets about by then.
I moved my 14x16 tractor shed twice. First time about 8 miles on a trailer, second time dragging it on the plates on gravel aprox 80 feet up onto a cement slab. Braced the door opening down at the plate with a 2x12, ran chains under it to the back wall corners, bent a scoop out of old pole barn tin to tuck under the back plate so it wouldn't bulldoze, hooked it to my 28hp 4x4 tractor and pulled. I used the 3 point drawbar so I could lift some on the front wall where the chains ran under that 2x12 brace. Even my wife said it was easier than she thought it would be. I just put in creeper gear and it walked away with it. The gravel was the key I think as it is a heavy building made from 7 RR ties and sheeted with 1x12's then covered with tin.
Buda temple?Ok I gotta ask..... what is that structure above/behind your shed?
Buda temple?
