JD 2025R Seat snapped off when removing backhoe
   / JD 2025R Seat snapped off when removing backhoe #1
JackieM
Tualatin, Oregon
None yet
OOOOPSIE! My first time removing the backhoe and I put too much pressure on the seat post when lowering the boom. Is this as easy a fix as i'm hoping it is???
   / JD 2025R Seat snapped off when removing backhoe #2
Looks like a casting. Depends on the material for welding. I would check the price of a new part, then consider having a shop fabricating a replacement or repairing it. Once you have a new part price, a good judgement can be made.
   / JD 2025R Seat snapped off when removing backhoe #3
I’d probably just bite the bullet and get the part new from JD unless you or someone you know welds.
   / JD 2025R Seat snapped off when removing backhoe #4
Well, damn, that's an ouch.
   / JD 2025R Seat snapped off when removing backhoe #5
Seen lots of posts about the same issue in the FB groups, maybe on GTT too. I think I read that they are backordered from JD, so getting it repaired may be best.
   / JD 2025R Seat snapped off when removing backhoe #6
I'm not familiar with the 2025r backhoe setup, just curious how the seat mount can get broken while dismounting it?
Sent from my SM-G715U1 using TractorByNet mobile app
You and me both. I was following the instructions line by line, and even watched a great how-to video on YouTube twice, since this was the first time I've had to remove the backhoe. The only thing I can think of is the seat was tilted back at the time, and should have been tilted forward. Still, that was a BIG BREAK.
The good news is my dealer was delivering a rotary cutter yesterday (which is why I removed the backhoe), and the technician believes it's an easy part replacement and will take care of it for me. I may even ask about the warranty. Why not?
Thanks for the feedback, everyone!
   / JD 2025R Seat snapped off when removing backhoe #8
   / JD 2025R Seat snapped off when removing backhoe #9
I think the seat stays with the backhoe on that machine so the seat probably got caught on or hit something and broke.
   / JD 2025R Seat snapped off when removing backhoe #10
It does, I'm familiar with Kubota backhoes and there doesn't appear to be anything for the seat to catch on unless something goes really out of line.
That's why I was curious what the seat could catch on in this case, hopefully by identifying what happened a repeat can be prevented!
Luckily appears to be a simple bolt on part so shouldn't be a bad fix.
