AirOpsMgr
- Joined
- Apr 26, 2023
- Messages
- 130
- Location
- Pike Co. Georgia
- Tractor
- Kioti DK5310SE, Scag Cheetah II 72"
I'm staying with the R14's as I finish-mow 15 acres and they're great on the grass (and do pretty well in the mud when needed). I'm just going to be more careful in the future and spend a little more time when cutting sapplings.Sorry to hear of your trouble. Same thing happened to a friend with a JCB backhoe.
What could have been done differently to avoid this problem? I was considering buying the R14 tire for my Ford 545D, but the lower ply rating and your experience has made me reconsider. I need a wet/moist field tire and will be working around some cut saplings, but will avoid them if possible. I need a R1 or R14 style tread for rear tires, but now am convinced I need a higher ply rating and bias-ply design to minimize risk of punctures. Road Crew makes a 12-ply R1 tire but I avoid buying anything from the country where it is made. Any other viable tire options that you considered? Would a higher-ply R4 industrial tire with chains work okay? I hate to think of the damage such a set up will do, or even an R1 tread on grassy areas, which is why I have been considering the R14. Thanks.
Fingers crossed that this was just an unfortunate combination of my haste along with the right sharp stick in just the right spot.
