I have a gauge at the pump but not able to read it while alone.
The motor is rated to a 300 ft. If at full load but I do not expect more than 150'.
No try with both motor and ram at the same time yet.
My thought was that the cylinder size and shock along with all unused flow having to go through the relief valve causes the engine stall? Like when valved only into the ram, it takes almost nothing so the rest of the flow gies to the relief valve at 1500 psi so I have instant 1500 psi braking pressure?
Gray
Another quick thought with a suspended load you may have to put a restictor [flow control] in the down side of a circuit. Restrict the flow of oil leaving the cylinder so it will not cavitate. Do not restrict both side of the cylinder you will just make the cavitation worse. CJ
I think what you are saying is the same as an over-running load.....yes, a restrictor (flow control) in a meter-out position would work
maybe a counterbalance valve plumbed and tweeked in to the bottom of cyl would help too with the suspended (over-running) load
