New to hydraulics
   / New to hydraulics #11
The grease is used to hold the oring in place. Don't matter what u use as the little bit won't matter. As long as u lubed them and they stayed in place you'll be fine.
   / New to hydraulics
Install went well, no leaks afterwards, so successful. :laughing: Just had to remove the seat, which was easy. Did not have to take off tire.
Here's the valves installed under the seat.
One of the valves with the o rings installed in the slot.
The valves all bolted together.
The parts as they came.
Back view before hoses attached.
   / New to hydraulics #13
The BH return line should go to a return line or directly to tank.
So I also have a L5030 with rear ports for my backhoe attachment which I am guessing is a power beyond setup? If the hoe is not attached I have to connect the supply line back into the return line. Since these are already back there is there a way to connect to them for both another set of rear remotes from the cab as well as another function on the hoe such as a hydraulic grapple etc...?
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
Ran during check in. No longer running. (A51694)
Ran during check...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
