hi
im pretty new with tractors and hydraulics. hoping you can help me out.....
ive got a ford 3000 with a front end loader. i have a 3 point hitch backhoe, id like to use. the backhoe has 2 hydraulic lines off it, that
run up to the hydraulic bank where the controls are. it also has its own hydraulic fluid reservoir (im assuming thats what it is) but
nothings connected to it. the 2 ports are just plugged with a bolt.
the tractor. has some rear hydraulic lines that come from under the seat to the back. im wondering if i put the same quick connectors as
the backhoe on there, can i use that to power it.
heres a picture album i put together with descriptions.
Imgur: The magic of the Internet
if its not the right part on the ford, can i replace it with something else that is? and what would that be?
or the other option is, the front loader runs off a pump at the front of the tractor. can i tee off the lines from the pump, and run some
lines to the back for the backhoe?
thanks a lot.
thanks a lot.
