Snow Annihilation
So I have seen this subject discussed here before and though I would thrown in my opinion on a JD 3520 vs. a JD 3720. I have owned both.
2 years ago I purchased a JD 3720 with a 300cx loader and lorenz front mount snow blower. At this time I looked a 3520 and 3720 and being my frist tractor threw the extra 3k for the 3720 being as my primary purpose is snow blowing and wanted to make sure I could thrown the snow as far as possible, we can get some nasty storms in Southern Oregon.
After 2 winters of freezing on an open station I traded the 3720 in for a 3520 with a cab. You may I ask why did not got for the 3720 with a cab....3k dollars, which is half the cost of the cab. So what do you get for 3k under the hood being the two tractors are otherwise identical. After parts research and talk with the mechanic at the local dealer. All you get with a 3720 over a 3520 is larger injectors, a different injection pump and different turbo and an intercooler. In terms of real world power a 3720 is 44 hp at the motor and 35 at the pto. A 3520 is 37 at the motor and 30 at the pto.
After driving and using both a 3520 is a better machine! Here is why:
The 3720 if it meets and resistance and you get on the hydrostat you will spin the tires 3 times sooner than on the 3520. The power to weight ratio is off. I have dug a hole with the tire in the 3720 in less than 30 seconds. The 3520 will spin the tires but with much more effort meaning that the power to weight ratio is where it should be and traction is applied. For snow blowing no difference has been noted and I am warm now.
The cost if you have the extra 3k to spend an want more tractor, step up to a 4000 series, you will get 4 cylinders over 3 cylinders and another 900 lbs of machine. In many instances there is no replacement for weight. I am not saying to not buy a 3720 it is a great machine and is like the high output v8 as opposed to the standard v8. Remember this is a tractor not a car. So my oppinion is to buy a 3520 or if you want more power step up to a 4000 series.
Hope this helps
Hope this helps
