Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 41
  1. #1
    Platinum Member glc24's Avatar
    Join Date
    Dec 2009
    Posts
    843
    Southwestern, Pa.
    Default SE SEAT FOR MY 2520
    I started to figure a mount for the SE seat today. I didn't realize until I took the seat out of its box that the dealer had included the "Attaching Parts Kit" at no extra charge to me...........nice
    Starting from the upper left,the first and second pics are what comes with the kit. The third pic shows the original seat sliders. They are unbolted,that's why the one is leaning. In case you were wondering The fourth pic is the seat bracket that bolts to the sliders,and the fifth pic shows what I'm going to remove. I shouldn't have too much trouble,there is only those two small circular welds and the two small beads. I'll drill through the holes and use a cutoff wheel on the beads.
    So far,unless something won't work out,the two pieces on the new seat shown in the lower left pic,is (hopefully) all I'll need to use. In the last pic,I'm holding the seat bracket. It's hard to tell from the pic,but I need another 3/8" on each side,so the brackets on the new seat end up on the outside of the bracket I'm holding. If I can't hold those seat brackets in the mill vise,I'm sure I can die grind 3/8",so as to make a slot and slide the brackets out to give me the necessary 3/4".
    I may have to do something to the back of the original seat bracket where the new seat brackets will rest. I won't know what I'll need until I get the said tasks done.
    kennyd,if you see this,might the attaching parts kit help you out getting that seat on your tractor?
    Greg
    Attached Thumbnails Attached Thumbnails SE SEAT FOR MY 2520-seat-change-001.jpg   SE SEAT FOR MY 2520-seat-change-002.jpg   SE SEAT FOR MY 2520-seat-change-004.jpg   SE SEAT FOR MY 2520-seat-change-005.jpg   SE SEAT FOR MY 2520-seat-change-005a.jpg
    SE SEAT FOR MY 2520-seat-change-008.jpg   SE SEAT FOR MY 2520-seat-change-009.jpg
  2. #2
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Default Re: SE SEAT FOR MY 2520
    You got me thinking again!
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  3. #3
    Join Date
    Dec 2009
    Posts
    843
    Southwestern, Pa.
    Seat is on the tractor
    First pic shows the tractor slider bracket with piece removed.
    Second pic shows the seat brackets and seat installed on tractor.
    Third pic shows the material I removed from each bracket.
    I slotted the seat brackets on the mill as much as possible,but I still couldn't get enough distance to put the seat brackets on the outside of the slider bracket. I ended up with about a 5/8" long slot.
    I figured what would be wrong with putting the seat brackets on the inside. I had to take a bit of material from them so they would clear the slider bracket when tilting. It wasn't a big deal. The only other mod was what is shown in the third pic. That wasn't much work either. The rod that holds the seat to the bracket is longer than it needs to be now,being the brackets are inward more than the stock seat. I may cut it down or just leave it be. I think I'll add a piece of rubber under the seat so there is ever so slight of a gap between the mating surfaces of the seat and slider brackets.
    One other thing that needs attention is the cluster of wires directly behind the seat,because when you slide the seat all the way back you can hear it pushing against them.
    The seat mod went alot better than I anticipated. If anyone is thinking of doing this,seriously consider the kit for this seat. Even though I only used the two seat brackets,it sure made it easy and saved alot of time having to fabricate something.
    Sorry I didn't take separate pics of what I did to each seat bracket. I was in a hurry to get it on the tractor before dinner.
    Yeah,it's overpriced (what isn't that has John deere on the box),but I think it's well worth it in the long run.
    Final picture is finished product and ooooh man,is it ever nice to sit on!
    Greg
    Attached Thumbnails Attached Thumbnails SE SEAT FOR MY 2520-seat-change-013.jpg   SE SEAT FOR MY 2520-seat-change-014.jpg   SE SEAT FOR MY 2520-seat-change-015.jpg   SE SEAT FOR MY 2520-seat-change-019.jpg
  4. #4
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,336
    NW Oregon
    Deere 317 & L118
    Looks pretty comfortable. It will make seat time even better.
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, CU72 Jake Rake, Middle Buster, 60" Landscape rake, 54"x 48" Pallet forks
    2005 John Deere L118
    42" deck
    Check out my rakes: www.Jakesimplements.com
    Check out the latest small engine I am working on: http://www.northwestsmallenginerepair.weebly.com
    Member of the TBN "Young gun" Club
  5. #5
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Did you happen to measure the before/after height?
    John Deere 4110HST
  6. #6
    Join Date
    Dec 2009
    Posts
    843
    Southwestern, Pa.
    Hey Ken
    There is approximately a 1" height change,only from the thickness of the SE seat,not because of the mount. It worked out pretty good,being the oem seat was higher off the slider bracket front and back. The SE sat lower but had more thickness,so they kind of evened out.
    Greg
  7. #7
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Quote Originally Posted by glc24 View Post
    Hey Ken
    Greg
    Interesting...others reported 3" or so in the older post's I researched. But they did not use the bracket you did...I'll have to check and see if you can just buy those instead of the whole kit.
    I may have to revisit this project, I have had no luck selling mine yet on CL. One guy did call me from my TBN classified add but he wanted it for about $100 or so-I told him I would make a bar stool out of it before I gave it away!
    John Deere 4110HST
  8. #8
    Join Date
    Dec 2009
    Posts
    843
    Southwestern, Pa.
    I measured again when I got home from work. The average is still basically 1". If you use the front of the factory seat,you can get as much as 2". It's difficult to get a really accurate height difference because the SE seat is pretty much level (there may be just an ever so slight tilt downward in the front) front to back. The factory seat has a much more pronouced tilt downward in the front.
    Also the factory seat has a taper,larger in back smaller in front,whereas the SE seat is the same thickness front to back. Like I stated before,all in all,it's a pretty even swap height wise.
    Greg
  9. #9
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,781
    Central New Hampshire
    Kubota B3030HSDC
    Your bum oughtta like that ! Needs yeller arm rests though.
  10. #10
    Join Date
    Apr 2007
    Posts
    220
    OC, OREGON
    JD 2320
    Greg
    What did that end up costing you?
    JD 2320
    200CX
    62D
    MCS
    And other stuff...
Similar Threads
  1. 2520 suspension seat?????
    By Deadman in forum John Deere Owning/Operating
    Last Post: 08-10-2011, 12:18 PM
  2. What's the deal with the 2520 seat? feedback please
    By Qhorse in forum John Deere Buying/Pricing
    Last Post: 03-17-2008, 04:03 PM
  3. Backhoe 2305 rotating seat for backhoe work
    By raykos in forum John Deere Owning/Operating
    Last Post: 03-16-2008, 08:15 PM
  4. 2520 first impressions vs 2210
    By bheston in forum John Deere Buying/Pricing
    Last Post: 07-28-2007, 06:58 AM
  5. Suspension Seat for B7500
    By chim in forum Kubota Owning/Operating
    Last Post: 05-10-2004, 12:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
