Page 1 of 7 1234 ... LastLast
Results 1 to 10 of 61
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    5
    Default John Deere 2305 Compact Tractor Transmission and rear PTO failure
    I have continued this posting from a previous one that was getting quite lengthy, the purpose of this thread is to share and gather information on a John deere 2305 rear PTO failure and transmission housing repair and to seek knowledge and support on a class action suit against John Deere and gather fellow disappointed 2305 owners for this righteous pursuit.
    See pictures of this catastrophic failure attached at bottom of this thread...
    Here is my posting from back in May 2010 from the previous thread...links to the old posting and another one like it attached below....
    Unfortunately I found this posting and many like it all over the web on how the John Deere 2210 and 2305 has had catastrophic rear PTO failures and problems. The reason I am here and writing this is to join the increasing number of dissatisfied consumers of this tractor. Same situation that I am finding more and more by searching the net and talking to other 2305 owners,tilling or bush hogging, hit something where slip clutch doesnt disengage for one of many reasons (load not significant enough to cause clutch to slip, froze up from rust or paint, etc...), and rear PTO housing gets completely destroyed. I took this immediately to local Koenig John Deere dealer where purchased 3 years prior, only to find out 2 days later, they have seen this exact problem before and my bill is over $6000. $3300 of which is just parts. And wait, it gets worse. Service manager at this dealership tells me this is a known problem and JD has since "beefed up" this transmission housing to prevent this problem. I was in shock! I took my broke 2305 back home to evaluate it myself because i couldnt believe they were correct. After 45 minutes of removing parts to get into the rear transmission, my nightmare came true. The thin, badly engineered cast aluminum housing gave way. How JD ever expected the already brittle cast aluminum metal(only 1/8-1/4" thick on outer wall) to withstand any torque at 540 RPM under a load is insane. And the kicker of all this is, their redesign of this is the only parts offered, so the remaining pieces i could have salvaged that were not destroyed are trash, and i have to completely replace ever part in the rear housing on my dime. This tractor is warrantied for 36 months on the drivetrain or 2000 hours. Of course my tractor is 6 months out of warranty and has less than 300 hours of total run time, of which only a few hours of use on the rear PTO. A supervisor from JD is supposedly going to get back with me in the next 48 hours to discuss, but my hopes are dwendling of getting them to help I will keep you posted as to how they handle this situation. If it turns out to be negative support from John Deere in helping owners of the 2210 and 2305 to repair their machines, i would like to know if any other members on here are interested in joining my lead in a class action lawsuit against them. Thanks
    Supervisor from John Deere called me back today. She first said that "With your tractor being 2 years out of warranty and with 600 hours on it, we can not offer you any assistance." I then had to inform her that both of those statements were false. My tractor has 200 something hours and is only 6 months out of the drive-train warranty. She had already made up her mind and insisted that there was nothing John Deere would do. Is this the type of service and quality that most John Deere consumers are subjected to? I am working my way up the ladder trying to get some assistance on this matter.
    Long story short after hours and hours on the phone with dozens of different John Deere managers and customer service representatives, including the territory rep here in southwest Ohio, John Deere didn't lift a thumb to help me on discounting parts or labor for this repair. In the end, the owner of the dealership where the tractor was purchased, gave me an 18% discount on parts, mainly to just get me off his back. After an exhaustive battle for almost 3 months, and without my front end loader and mower (manure piling up and grass getting high), i gave in and bought the parts at the discounted rate. It took 4 friends and myself working very hard 1 whole weekend and 5 nights after work repairing this transmission. Attached are pictures of the flaw and repair. Note: The new transmission that replaces the old has an bearing wall thickness nearly 3 times thicker than original design. What a nightmare this has been.
    It is now that i feel that a lawsuit to force John Deere to reimburse all 2305 owners who have had to make this repair themselves on their dime and to force a recall of all 2007 and older 2305/2210 tractor to have the new transmission design installed.
    If you have an interest or questions about this repair, please email me directly at JBarnes6767@gmail.com or send me a message on this site.
    Thanks
    Jacob Barnes
    http://www.tractorbynet.com/forums/j...ower-take.html
    http://www.tractorbynet.com/forums/j...-take-off.html
    Attached Thumbnails Attached Thumbnails John Deere 2305 Compact Tractor Transmission and rear PTO failure-0508000833.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-0508000833a.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0491.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0490.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0554.jpg
    John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0547.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0530.jpg   John Deere 2305 Compact Tractor Transmission and rear PTO failure-dscn0528.jpg
  2. #2
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,801
    Red Oak, Texas
    JD 5525 and 4520
    Default Re: John Deere 2305 Compact Tractor Transmission and rear PTO failure
    Quote Originally Posted by JBarnes6767 View Post
    Thanks
    Jacob Barnes
    That sucks - JD should supply kits at a significant discount.
    D.
    Darin Divinia
    DDR Longhorns
    Registered Texas Longhorns
    http://www.ddrlonghorns.com/
    Follow us on Facebook:
    http://www.facebook.com/DDRLonghorns?ref=ts
  3. #3
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,093
    Westminster, MD
    John Deere 4110
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  4. #4
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,801
    Red Oak, Texas
    JD 5525 and 4520
    Do you have a comparison of the new vs. old parts?
    Would be interesting to see the size differences.
    D.
    Darin Divinia
    DDR Longhorns
  5. #5
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,010
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    My hat off to you for taking on that task. Great job. That is a major tear down. I have a 2305 but rarely use the pto. Poor job and support on JD's part.
  6. #6
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,336
    NW Oregon
    Deere 317 & L118
    very interesting. i have read way to many threads addressing this same issue and today, it may have happened to my grandpa's 2210. he was mowing the lawn with his 54" MMM and hit a root. Instantly killed the tractor and bent the mower blade. He just started it right back up and finished mowing. Got the blade fixed but the whole rear end of the tractor vibrates real bad, especially at mid RPM but the PTO still works. Reading this review, that seems like a lot of hard work just to fix one of John deere's mistakes. Also, when you have it in the rear and rear/mid PTO range, the PTO brake is set but when it is just with the MMM, the brake does not work for the rear PTO. is that normal? I hooked my tiller to it recently and had it in mid PTO range but remember the PTO brake being set since it was a hassle to hook up the PTO shaft. i may be wrong but there is something wrong in the tranny.
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, CU72 Jake Rake, Middle Buster, 60" Landscape rake, 54"x 48" Pallet forks
    2005 John Deere L118
    42" deck
    Check out my rakes: www.Jakesimplements.com
    Check out the latest small engine I am working on: http://www.northwestsmallenginerepair.weebly.com
    Member of the TBN "Young gun" Club
  7. #7
    Gold Member Pushing_Tin's Avatar
    Join Date
    Oct 2007
    Posts
    414
    Eugene, Oregon
    JD 3320
    Sorry to hear about your troubles. The unfortunate truth in the internet day and age is that you have to make a big stink online in order to get any attention. This is true with any company these days. I have read time and time again where a company which is being completely unfair or ignoring a consumer with a legitimate complaint only steps up when the consumer's facebook, blog or twitter account posts the problems for the world to see. You could start a twitter account for free, and register mylemonjondeere.com for $10 and start peppering them with negative publicity. Perhaps then you might get some of your money back.
    2010-3320 e-hydro 300CX
    LA105
  8. #8
    Advertiser
    Join Date
    Mar 2009
    Posts
    6,336
    NW Oregon
    Deere 317 & L118
    here is the link to the video of the noise in the tranny. John deere 2210 tranny noise - Tractor Videos - Kubota, John Deere, New Holland and More
    My Fleet:
    42" deck
  9. #9
    Join Date
    Oct 2007
    Posts
    414
    Eugene, Oregon
    JD 3320
    LA105
  10. #10
    Join Date
    Nov 2009
    Posts
    1,701
    USA
    Bobcat
    Quote Originally Posted by Pushing_Tin View Post
    I disagree with this statement, there are still a lot of companies who stand behind their products, it is too bad a great old name like deere is not one of them
Similar Threads
  1. John Deere Rear PTO for X585 BM20633 or BM21914
    By jmaness in forum John Deere Lawn & Garden
    Last Post: 07-12-2011, 09:22 AM
  2. Toolcat 5610 vs CUT review
    By radman1 in forum Buying/Pricing/Comparisons
    Last Post: 10-22-2008, 04:07 PM
  3. John Deere compact tractor 4110
    By elad in forum John Deere Owning/Operating
    Last Post: 12-23-2004, 10:30 PM
  4. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
  5. New Xtra Armor Kit From John Deere for 4000 Series
    By Muhammad in forum John Deere Owning/Operating
    Last Post: 07-09-2001, 09:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
