Is the leak from the valve core itself? Or is the leak from the stem itself? Could it be leaking from the outside edge of the valve stem? If it is a tube and leaks around the edge, maybe it is a hole in the tube. You just started working the tractor quite a bit and it doesn't take much to crack a valve stem. I just broke two off from hitting small branches and my tractor only has 50 hours on it. Could you take a picture and point out exactly where the thing leaks?
Good luck
Thanks Chuck , no it's not the stem , it was in fact the core being defective and breaking inside the stem. And no, I have never had this tractor anywhere that I could have snagged the stem on anything .
Here's what happened next and the results:
After waiting for hours to get a call back from the hardheaded sevice manager at John Deere my neighbor who is a farmer and knows tractors came by and took a look and found the same thing as I had been trying to tell that Dumb Cluck all along . It was in fact the defective core.
He said that all I need to do is go to the Farm Co-Op about 12 miles away and they would hook me up with a new core . I went right over there and picked up two for no charge which I thought was pretty decent. I came home and put one of them in and refilled with air and problem solved.
I knew it wasn't anything major to begin with but what I am ticked off about is the fact that John Deere's service manager refused to make it right with me. I lost a lot of
ballast on that tire and it was due to the defective part I received with the tractor upon the purchase.
I am still gonna go over that hardheads head by contacting John Deere Corporate and I even told him so. If they don't do anything for me so be it but at least I did all I could.
I will not spend any money on ballast so I may drain off the other side to the same level of ballast so I can get the tractor balanced evenly in weight. I may later just go ahead and get the ballast drained out all together and go to a ballast box or maybe Rim Guard. I sure don't like that Calcium Chloride one bit as it is pretty darn corrosive and I don't like the idea of it eating up my rims and stuff.
Anway thanks to all for your comments , if anything new comes up about this I will keep you all informed on this thread.
Thanks. :thumbsup:
