CK30 Injection Pump
   / CK30 Injection Pump #41
DSC03875.jpgDSC03858.jpgDSC03859.jpgSorry to tell you guys but the teeth in the pump gears are kaput! I had same problem @ 200 hrs Called dealer and was given cold shoulder as my tractor was a 2007 and warranty was up. Was told that for several years pump had a problem, Kioti knew but never fixed. Now they have new pump with better gears for $ 1076 + tax. Part # E5500-51015. Replaced pump and tractor runs fine. Took aproximatly 3 hrs had to remove intake manifold and hood. Took old pump apart and one gear had 3-4 teeth broken other two gears look ok. Anyone interested in used gears contact me @ triser@tampabay.rr.com.
   / CK30 Injection Pump #43
I have a ck25 and had pretty much identical problem, I removed the pump and had it rebuilt by bosh injector shop that I found locally. I was really fortunate it ended up costing less than $600 to rebuild
(APPROX 12) 2" X 6" X 41" IRON TUBING (A51247)
(APPROX 12) 2" X...
2002 CRESCENT 102" X 53' STEP DECK TRAILER (A51247)
2002 CRESCENT 102"...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2013 John Deere 824K (A53472)
2013 John Deere...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A51248)
UNUSED FUTURE...
UNUSED 3 PRONG BALE SPEAR (A51248)
UNUSED 3 PRONG...
