Results 1 to 10 of 17
09-30-2012, 06:46 PM #1Gold Member
- Join Date
- Mar 2009
- Posts
- 341
- Location
- Mobile, Alabama
- Tractor
- Cat 299D XHP, Cat 297c, Rayco C140
L5740
I'm looking for a tractor to do it all mow the lawn maintain driveway rake hay disk pastures and food plots. Looking at a L5740 with cab and front end loader an mid mount mower, anyone have one if so how do u like it? Also I have a 8 ft pull behind disk wonder if it would pull it?
Lifescapes Forestry Mulching/ Brush Cutting Services
251-331-4475
lifescapes-forestry-mulchling.com
09-30-2012, 07:01 PM #2Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,879
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Re: L5740
I don't think that you can get the L5740 with a MMM and as far as that 8" disk, if it has small blades maybe, but if you have 22"-24" pans, I doubt that it would pull it when down much deeper than 6"-7". Other than that, it is a fine machine. Very very tough to get a single tractor to do it all, good anyway.
Good luck.
09-30-2012, 07:30 PM #3
Re: L5740
To do what you ask for the disc it will be too heavy for the lawn...Would also recommend R1 tires
Kubota L5740 La854
MF 35 Deluxe gas wloader...For sale
09-30-2012, 07:58 PM #4Elite Member
- Join Date
- Feb 2011
- Posts
- 3,804
- Location
- NOT HERE
- Tractor
Re: L5740
You can't get a 5740 with a MMM
It would be a heavy tractor to mow you grass with, around 7000lbs. Kubota says it will pull a 7' disk, sometimes they underrate, it may pull more. How about a L4240 for bigger tasks and a BX2360 for mowing your yard and smaller tasks?
09-30-2012, 08:33 PM #5Gold Member
- Join Date
- Mar 2009
- Posts
- 341
- Location
- Mobile, Alabama
- Tractor
We'll mowing the yard isn't a small task it 3 acres and ac make it much better in 100 degree heat already cut most of it with a challenger mt 285 with finish mower. Just want a cab tractor.
251-331-4475
09-30-2012, 09:08 PM #6
It is strange that the mmm is not listed as available for the 5740 but in the brochure I have has several photos of a 5740 mowing with the mmm.
Originally Posted by 94BULLITT
L3130 HST, LA723 Loader, TC18 w/ Front Mount Snow Blower, 3ph Bush Hog, 2 bottom plow, 3ph Finish Mower, Befco Spreader, Chain Harrow, Box Blade, 50 Gal Sprayer, Shaver Post Driver, Dump Wagon, Grader Blade, Agric Tiller, one row Cole 12mx planter, two row JD 71 Planter, 2 row Webb Precision Vegetable Planter, 13 foot Cultipacker, Cole Fertilizer Side Dresser, 2-row Cultivator, 1-row Cultivator, 9' International Disc Harrow, Subsoiler, Middle Buster, Subframe Backhoe, Vicon Vari-Spreader.
09-30-2012, 09:13 PM #7Elite Member
- Join Date
- Feb 2011
- Posts
- 3,804
- Location
- NOT HERE
- Tractor
10-01-2012, 07:08 AM #8Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,645
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Re: L5740
The same week I bought my L5740 HSTC a local company purchased one for grounds maintenance. I am guessing they pull gang mowers or an RFM. The company owns and builds motels, office buildings and such. We use ours in conjunction with our BX to maintain our farm, really nice tractor.
10-01-2012, 08:37 AM #9Platinum Member
- Join Date
- Sep 2009
- Posts
- 986
- Location
- Indianapolis
- Tractor
- Kubota L3940 Ford 8N Ford 6000
Re: L5740
Kubota L3940HST-1 2009
84" front blade
LA724 loader w/quick attach
HD 72" round back bucket
turf tires
Ford 8N 1950
Ford 6000 diesel 1961
JD LX188 1997
JD L110 2003
Woods RD7200 finish mower, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 3 point 2" drawbar receiver, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
10-01-2012, 10:25 AM #10Elite Member
- Join Date
- Feb 2011
- Posts
- 3,804
- Location
- NOT HERE
- Tractor
Similar Threads
Am I asking too much from my L5740-3?
By High Compression in forum Kubota Owning/OperatingReplies: 37Last Post: 07-16-2012, 09:07 AM -
L5740
By dieselbill in forum Kubota Owning/OperatingReplies: 8Last Post: 06-25-2011, 08:55 PM -
New L5740
By KnuckleDragger in forum Kubota Owning/OperatingReplies: 5Last Post: 05-13-2010, 04:11 PM -
New L5740
By JerryJHarrison in forum Kubota Buying/PricingReplies: 7Last Post: 10-09-2007, 09:20 PM -
L5740
By Kendall69 in forum Kubota Buying/PricingReplies: 8Last Post: 04-01-2007, 06:27 AM
