mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,310
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
After only 4 hours of work the excavator sprung a hydraulic leak, so it was back to working the L39 hard.
The excavator feeding the L39 operated by my wife should get some material moved once it’s fixed.
PS That's a 2100 - 2500 lb Rock in the bucket. Granite weighs 160 LBS Cu-Ft.
I am running about 2900 PSI hydraulic pressure with a 1 pint accumulator off the main pump to reduce hydraulic shock loads when carrying such a load over a bump. Note a JD 110 runs 3000 PSI so I doubt you hurt anything but the warrantee.
It is best to use a calibrated gage if you crank up the pump pressure.
To get 2900 lbs (at least on my L39) this has been my experience.
Only go 1/3 turn on the relief valve spring. The diesel at idle should not slow to the point of almost stalling with any hydraulic function. If you lift the rears off the ground even on an unweighted machine, you have way too much pump pressure. One tire lifting off with offset load is ok on an unweighted machine.
My +1100 extra lbs weight also keep me safer and stable. I strongly recommend adding about 1000 lbs weight.
