Telescoping Links on a 7500??
   / Telescoping Links on a 7500?? #1
garbageman
Orange County, NY
Kubota 7500
The turnbuckles on my tractor need to be replaced. Has anyone used the telescoping type on the 2910 on a 7500. If so do many changes needed to be made? What was the insulation like? My skills are limmited.
Thanks
Ray
   / Telescoping Links on a 7500?? #2
Did that on my B7800 and it is fantastic! Much easier to change implements: just pulling the locking pins; no more turning of turnbuckles! It also takes very little effort. I went to the dealer and told them what I wanted to do, they ordered the parts, and it only took me about an hour with some interruptions.
I did have to jack up the rear end, loosen one of the rear tires in order to get enough room to remove the shaft that operates the lower arms of the 3-point hitch. At least I did not have to remove the tire entirely - those things weigh a ton.
I originally saw this conversion on the Kubota chat board at SSC Tractor web site. I found it by searching for B-7800 and then looked for check chains.
Thanks DR Bob, I will asked my dealer if it will work, as your tractor is a little bigger than my B7500
Ray
   / Telescoping Links on a 7500?? #4
I did it on my B7610 which is about the same size physically as the B7500 I believe. Parts kit were from a B2910 and cost me about $130. sure makes hooking up implements (especially heavier stuff) a lot easier.
Thanks, thats what I want to hear. I called my dealer today who stated the parts would be from a Kubota 3030 and would cost $150.
Thanks for the PHOTO
Ray
BTW what was involved to install? Did you need to remove the rear tires?
Thanks again
   / Telescoping Links on a 7500?? #7
Thanks again
No you do not need to remove the tires. It probably took me somewhere between 30-40 minutes. I followed the instructions posted by another member here:
http://www.tractorbynet.com/forums/...ng/49403-b7610-3p-stabalizer-replacement.html
There is also a related thread here:
http://www.tractorbynet.com/forums/...g-telescopic-stabilizers.html?highlight=b7610
Other members have posted that they actually prefer the turnbuckles. See here:
http://www.tractorbynet.com/forums/...-point-hitch-stabilizers.html?highlight=b7610
For what it is worth, now that I have had both, I prefer the telescoping stabilizers by a wide margin.
   / Telescoping Links on a 7500?? #8
Prices got pretty high for the L series...so I made mine. :D
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
2018 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2018 JLG 2632ES...
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A54865)
1999 Volvo VN...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
