bx24 MMM compability
   / bx24 MMM compability #12
what about a woods mower ? or a RFM ?
   / bx24 MMM compability #13
I only paid $1,600 for my 60 inches 1.8 years ago..
   / bx24 MMM compability #14
Watch Craigslist and E-bay for used BX24. Call and ask if they will sell the deck separately. I got mine for $950 off a used BX24 with 50 hours on it. It will take some time for one to show up with a deck, but it worked for me.
   / bx24 MMM compability #15
Maybe someone here with a BX22/BX2200 could give you some measurements, like the distance between the rear lifting points on their decks and drive shaft length when hooked up. The front hangers are adjustable by a few inches in and out so those "should" fit. Just trying to suggest another way to skin the cat, so to speak.
   / bx24 MMM compability #16
Here's a possibility in New Haven County, CT. Maybe a bit far from Boston. Sorry, but I haven't figured out how to post a direct link to a craig's list add. There are pics in the original add.
Kubota Rotary Mower Deck - $1350 (new haven county)
Reply to: sale-cgmqc-1265942434@craigslist.org [Errors when replying to ads?]
Date: 2009-07-12, 11:41AM EDT
Kubota Rotary Mower Deck Attachment model # RCK60B-22BX. Used 1 season as home owner use only. 3 blades - fits Kubota Tractor model: BX23. Never left outside - always garaged when not in use.
Call Kris 203-650-8793
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1265942434
   / bx24 MMM compability #17
---------------Reply to: sale-cgmqc-1265942434@craigslist.org [Errors when replying to ads?]Location: new haven county
Don't sound too bad although I only paid $1300 for my new 60'' mmm for my 2004 BX23 .
   / bx24 MMM compability #18
I had the same question as the original poster about the compatibility and after doing some research I found that the mowing decks from the BX22 and BX 23 are not compatible with the BX24
drumline
do you recall specifically what wont work and why they are not compatible? I can do some cutting and welding, but if there are major mechanical differences then we have a problem. I heard that the bx24 is about 4inches wider than previous models and thus the mounts on the mower deck "may" need to be moved, that wouldnt be soo bad. I am looking for specific sifferences in order to determine if one deck can be "made to work"
thanks for the reply
   / bx24 MMM compability #20
I don't have any measurements for you but heres a couple pics of my at the time, brand new BX23 60" MMM.
IF someone has similar pics of the newer BX24 60" MMM you should be able to at least see the differences.
Good luck.
PS, I was experimenting w/a mulch plug and it didn't work out very well.....
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
1293 (A58374)
1293 (A58374)
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
